Old 09-07-2015, 08:23 PM   #1
Airmech
Tires?
I am curious to know what tires are coming on the knew sandpipers. Looking at getting one in Feb or mar. Am wondering if I should be including different tires in my customization list.
Pilot- Aaron, Copilot- Erica and Licker- Lizzy and Abby
5ver- TBA
2001 GMC 3500 Dually
smittyams is offline   Reply With Quote
Old 09-07-2015, 08:38 PM   #2
Commercial Member
Ask your dealer
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 09-10-2015, 08:15 PM   #3
5erDriver's Avatar
Westlake tires and sumec wheels
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 09-10-2015, 08:43 PM   #4
Airmech
Thanks, something else for the list.
5ver- TBA
Old 09-10-2015, 09:10 PM   #5
5erDriver's Avatar
Yeh. There's always a list!!
I replaced one on the last 5er with sidewall damage for a Goodyear Marathon. Great tire. We just got the new 5th wheel 3 weeks ago. I might run the tires all of next year and then change out. See how I feel in the spring. Maybe change out cause don't need a problem. The Goodyear was $150 mounted. Range E.
Old 09-11-2015, 07:27 AM   #6
Airmech
And that's why I asked, I had a friend with a cougar that had less than 3k on the tires and he had a blow out coming back from a trip. Did a lot of damage and was extremely lucky he had the exit right in front of him.
5ver- TBA
Old 09-11-2015, 07:56 AM   #7
dieselguy's Avatar
I and friends have had late model fivers of various brands in the 12,000# plus range. The Goodyear "Marabombs" would not hold up and we all eventually chose alternate tires whether Goodyear G14's or G rated LT tires like Firestone, Uniroyal, or B F Goodrich makes. You can read pages and pages, and pages of "Marabomb" failures on the heavier RV's. Some times Goodyear stepped up and paid for damage due to blow outs and credit towards alternate tire choices. The key to those instances was keep the tire carcass for Goodyear's inspection. Some of us sold our "Marabombs" to farmers as they use them on low speed farm trailers. The "Marabombs" do seem to work with the lighter RV's around 6,000#.
dieselguy is offline   Reply With Quote
Old 09-11-2015, 07:59 AM   #8
Airmech
I was leaning toward the Lt if nothing else could be found.
5ver- TBA
Old 09-11-2015, 08:26 AM   #9
kcjoe1's Avatar
I thought that I was taking good care of my China Bombs but a couple of weeks ago I found one that was low on air. MMMMmmmmm So, got home and took the tire off and took the soapy water to it. It took a couple of minutes to find it but sure enough right next to the wheel was a very small split in the tire. It didn't appear that there was any kind of road damage so I took it in to the RV dealer to ask him about it. Since we were just over our one year warranty he said " just buy another tire and put it on, the other ones will be just fine". I asked him if upgrading to an E rated tire would be better. " That's just overkill why would you want to do that?" He also mentioned that the C Rated tire that are on our 8289 WS are close to the max limit. MMMmmm Well, I decided to go with the E rated Carlisle radial trail tire from Discount tire and What a difference it made. We made a 1300 mile trip to ND and back and there is no more sway. The stiffer side walls made all the difference on how the truck and RV go down the road. I don't have to fight the wheel any more. I know too that Discount tire is all over the country so I know where to find a replacement should on be needed.
Happy Camper
Compare
Carlisle Radial Trail RH Trailer Tire
2017 Arctic Fox 27-5L
2014 Rockwood 8289WS Diamond Package (SOLD)
2008 Dodge Ram 2500 SLT 4X4, Anarchy Tuning
kcjoe1 is offline   Reply With Quote
Old 09-11-2015, 08:28 AM   #10
5erDriver's Avatar
My new 5er is 13,500 and change dry. By the spring and certainly before we hit the road next summer I will likely change up. Anything to reduce potential for trouble and damage on the road. The tires have gotten a little better since the DOT started to oversee them but not a season goes by without hearing several stories of blowouts.
tire, tires
