Old 11-02-2013, 03:18 PM   #11
Originally Posted by BarryD0706 View Post
Please read posts 7, 9, & 13 in this thread: 5th Wheel Towable With 1/2 Ton Truck
Don't really think that has much to do with his ability to carry the load if he wants to do it. He will be the one to foot the bill if the rear end doesn't carry it.
If what they say is true that the only difference between a 250 and a 350 is the springs, his airbags will offset the spring difference.
Cautioning folks is one thing, but trying to put the fear of the law is something else IMO.
Old 11-02-2013, 03:58 PM   #12
golfmedik's Avatar
My pin weight on my 365 is around 2900/3000 pounds as I carry water with me. That would be over the RAWR for your truck. My rig combined is around 25k which was over the GVWR for the '10 F350 I have but not over my '13. Yes, it is true that the only difference between the 250 and 350 is the rear springs. Go to Ford's website or Google it and you will find the payload capacity difference. That is what I am talking about here. The air bags won't change how much the truck can carry(legally) but it helps you carry it more effectively. That being said, LOTS of people pull them just fine with F250s. It would just depend on how you feel about pulling that much weight knowing what the manufacturer's recommendations are. Good luck..Oh and you'll love the 365!!!!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is online now   Reply With Quote
Old 11-02-2013, 04:02 PM   #13
btritschler1437's Avatar
Some of the differences for a 2011 model Ford 250/350 SRW
Rear Axles: F-250 6,280 lbs; F-350 7,280 lbs these ratings are made up from spring rates, tire ratings & wheel strength - not because the axle assembly is different from model to model
Brakes: F-250 vacuum boost; F-350 hydro-boost (diesel only)
GVWR: F-250 max 10,000 lbs; F-350 max 11,500 lbs (SRW configuration)
Brake rotor diameter is the same on both models 13.66" front, 13.39" rear
Springs: F-250 two rear leaf spring; F-350 three rear leaf spring
Size of the blocks between the rear axle and rear spring
Bob & Sharon, "15 Cedar Creek 38CK Custom, '13 RAM 3500 Laramie, 4x4, LB, CC, DRW 6.7 Cummins HO, Aisin 4.10"
btritschler1437 is offline   Reply With Quote
Old 11-02-2013, 05:30 PM   #14
I think it's pertinent and not fear mongering that someone knows all sides of the issue. There have been posts on here from folks with direct experience that have indicated that if you're grossly overloaded that your liability risk increases. Not knowing the OPs background or prior knowledge, I think it's only fair to share the information from both sides. He may not have thought of the ramifications of the choice.
Will the truck pull it? Seems almost certain.
Will he be grossly overloaded? My gut/off the cuff thoughts say yes (especially after seeing the almost 3k pin weight for a 365saq).
I think if this person wants to overload their vehicle, they should do knowingly.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
Old 11-02-2013, 05:39 PM   #15
Ford Idaho's Avatar
Just knew I should a bought that F650.......
Old 11-03-2013, 01:40 PM   #16
Do not want to start an argument, but having driven otr and 8 years as a city p&d, my feeling is not so much will it "pull it" but will it "stop it"??
2014 Sandpiper 35ROK
2004 Volvo VNL64T 630 left tandem
D-12 435 HP 740 CU
Golf car has died-looking for another one
Arguing with some people is like trying to smell the color 9
Volvodriver is offline   Reply With Quote
Old 11-03-2013, 02:22 PM   #17
Oakman's Avatar
I thought firedude had his question answered in post #6.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 11-03-2013, 04:38 PM   #18
5erDriver's Avatar
I say yes. With the airbags I'm sure it will pull like a dream and power is a non issue with that truck. I pull our 2013 with a 6.4 Powerstroke 350 SRW. Pulls just beautifully. Don't pay any attention to the advertised 11,873 lbs or whatever the listed dry weight of the saq is though. That's a generic dry weight from the product line and is on every dealer website you will look at as the units weight. You need to see the yellow sticker with the actual individual units weight as weighed upon completion at the factory with all options added. Ours is 12,700 and change dry. A big difference to the advertised. We just ended or first full season with our 2013 today. Just got done winterizing, sadly. You will love the 365! Good luck with it.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 11-03-2013, 06:50 PM   #19
Thanks to All!!!!
Thanks to all of you for your responses and expertice.... We hope to purchase our 365 in the spring..... After everything said I think I will hit the local scale and weigh my truck and see just how much over my gvw rating we will be.... If its too much we may have to go a little smaller and lighter,,, not sure yet... I drive a firetruck for a living, so pulling the monster doesn't scare me.... the legal stuff does, god forbid anything should happen.... Thanks again for all your help.. Happy camping...
firedude is offline   Reply With Quote
