Old 10-22-2016, 10:21 AM   #1
Tv elevator top mount question
We have a 2017 389rd with the rear tv that comes out of the cabinet.
Our top piece of cabinet is not attached it just lays up there.
Is that how everyone elses is? If not can someone show a picture of there mounting system?
brad2388 is offline   Reply With Quote
Old 10-23-2016, 07:19 AM   #2
Ours is screwed to a bracket that runs the length of the tv from underneath. Hard to get a picture but I will try later today.
acyale is offline   Reply With Quote
Old 10-24-2016, 01:38 PM   #3
Mine just sits on the TV. You can just lift right off.
Mikele is offline   Reply With Quote
Old 10-24-2016, 06:13 PM   #4
Thats the way ours is. Sucks but it is
Old 10-25-2016, 01:32 PM   #5
keith52's Avatar
Ours has an "L" shaped bracket that fits into the lift at the top. It is not screwed into the lift and the top board including the bracket just lifts off. 2017 Cedar Creek 36 CKTS.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 10-25-2016, 06:17 PM   #6
DTingle's Avatar
My counter top portion is screwed to a bracket which is in turn bolted to the lift arm that comes up out of the cabinet.
2011 Ford F-150 Crew Cab w/ Ecoboost
2013 Rockwood 2703SS
DTingle is offline   Reply With Quote
Old 10-25-2016, 06:40 PM   #7
New to FR. Old to TT
one of the reasons for the loose top is for safety you could run the tv down and at the very least pinch a finger or even more damage. I have built custom furniture with lift units and I always use a friction catch to hold the top in place so it can release if anything gets in the way. or you can use a hinge that pivots the top to the back of the tv when raising.
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
Tall frog is offline   Reply With Quote
Old 10-25-2016, 07:17 PM   #8
NMWildcat's Avatar
Our 'flap' is attached to the counter top with a full length piano hinge. The top of the rail system that holds the TV pushes it open when raising the TV. Automatically (gravity) closes when the TV goes back down. Works well!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 10-26-2016, 12:36 PM   #9
Old 10-27-2016, 07:42 PM   #10
Originally Posted by acyale View Post
Ours looks like this as well.
But out ack piece just slides over the upright. How is yours attached there?
mount
