Old 06-26-2016, 01:05 PM   #1
TV removal
How do I remove tv from wall bracket in sandpipper 2016 FL
Henry4854 is offline   Reply With Quote
Old 06-27-2016, 10:50 AM   #2
head gamez's Avatar
If you feel behind the tv from the bottom, you should find a "pull cord" made of nylon webbing. You pull down on it and will free the bottom latches on the mount. You then simply tilt the TV from the bottom (tilt the bottom out) and lift up.
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 07-04-2016, 10:23 AM   #3
Checked no release, bolted on bracket very tight
Old 07-04-2016, 10:55 AM   #4
jtstromsburg's Avatar
How about a picture or two to help have a look.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 07-04-2016, 11:10 AM   #5
Ford Idaho's Avatar
Flashlight, contort yourself into the pretzel position.
Now look behind the tv from one or both sides, do you note a red or perhaps yellow tab?
If so and you can reach it push or pull forward, if you can not reach it us a long screwdriver.
Old 07-05-2016, 06:34 AM   #6
Couldn't find any tabs or release straps. Two screws at top and bottom unable to find a tool as of yet that will fit in close quarters to loosen the screws, dynamite might be the next step--
