02-11-2017, 06:49 PM
TV through stereo
I have 2014 35ROK Sandpiper.
Can you play the TV sound through the built in stereo?
The TV sound is terrible!
The Garner's
2013 35ROK
02-11-2017, 06:51 PM
Left Coast
Mine will
02-11-2017, 07:09 PM
Hmmm.....thanks, guess I'll keep messing with it to see if I can figure out how to get the TV to output to the stereo speakers.
The Garner's
2013 35ROK
02-11-2017, 07:11 PM
Left Coast
Might be in stereo settings....
02-11-2017, 07:13 PM
Thanks Bob, I will back at the RV tomorrow and will play around with it.
The Garner's
2013 35ROK
02-11-2017, 07:17 PM
Left Coast
Been a long time since I did it..
02-11-2017, 07:30 PM
Who Dares, Wins
I have not has any of my trailers hooked up to the stereo speakers by default. On our Mini Lite I opened up the radio and behind it was a whole bunch of unused RCA type jacks. Ran a L and R stereo to the TV's RCA hookups and had surround sound.
2015 Chevy HD D-Max
2022 Impression 315MB
02-11-2017, 09:41 PM
Thanks.....I'll let y'all know how it goes.
The Garner's
2013 35ROK
02-12-2017, 12:04 AM
We had to change the input/output source on the stereo then turn down/off the volume on the television to avoid echo sounds on the surround sound speakers. Just gotta play with the remotes until you figure it out!
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
02-12-2017, 02:06 AM
The quick and easy way is to run a patch cable from the TV audio out to the entertainment centers audio in. Usually there is an audio in located on the front that takes a 3.5 mm mini. The TV may have the same or most likely standard RCA jacks.
02-12-2017, 04:49 AM
As previously mentioned, there has to be a connection from the TV to the stereo. Assuming the cables are there, check the input or sound source menu on the stereo. There should be options for FM, CD, TV, etc. I had the cable connection...just had to play with the menu.
2017 Chevy 2500HD, 6.0, 4:10 Gears
2019 Flagstaff 26FKBS
02-12-2017, 09:26 PM
Frustrating to say the least!
I can't even get the setup menu to come up. Guess I will have to pull the radio and see if they ever hooked the RCA cables up.
The Garner's
2013 35ROK
02-12-2017, 09:45 PM
I open my remote menu, and go to 'HDMI ARC' or something similar..... (Audio Return Channel). The TV has to be capable of doing it. Then it works.
(I learned all that on here!)
FROG AR-0019-242
02-12-2017, 10:36 PM
Thanks but I can't even get the Menu to display
The Garner's
2013 35ROK
02-13-2017, 05:45 PM
Not familiar with your particular unit but in a previous Rockwood could play tv sound thru stereo by selecting the input on the radio to something like A/V . This presumes an input is connected from tv sound out ( usually red and white jumpers) going to radio
Other Motorhome
2013 F-150 Eco-Boost V6
02-15-2017, 01:26 AM
From the headunit (if has a DVD player in it) to tv they use rca composite cables (red yellow white). Unhook them on the tv side and use a female rca (red n white) to 3.5mm mini stereo cable plug it in to the headphone port on tv. Pull the headunit out. Unplug red/white rca and use another Y to 3.5mm. Plug that in to the AUX input in front. Look for one with a L elbow to make it cleaner.
Prob solved.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
02-15-2017, 08:40 PM
Does it have the stock crappy sound bar? Your TV will have an optical out, or RCA out into the bar then you have to select that input on the sound bar.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
02-16-2017, 12:52 PM
No it doesn't. I've ordered an RCA to 3.5 cable and will plug it into the front AUX to see if I can get it to play that way. If it does then I'll work on tracing the cables from radio into wall to be sure they are actually connected!
The Garner's
2013 35ROK
