Old 08-28-2012, 08:10 PM   #1
Hatchet58's Avatar
Under the 5th wheel
Question, on a recent trip to Colorado and back to Seattle area, I noticed the fiberglass under the 5th wheel sagging , When I looked at it closer I found that 5 out of the 12 screws was broken and the others where loose.. Has any one else had this problem ??? the only thing I could think of is that the wind caught it by the 5th wheel plate and loosened those first, then the wind did more with the fiberglass whipping up and down ..... anyone have a Idea ????? I redrilled the holes and installed new Screws
Hatchet
Chevy 2500HD Diesel
07 SandPiper F305
Days camped 2011 "3" so far,
Hatchet58 is offline   Reply With Quote
Old 08-31-2012, 07:33 PM   #2
golfmedik's Avatar
Sounds like they didn't do a good job in the Quality Control area when it came off the line. All of the screws may not have been tight thus led to the problem you found. Could just be a fluke. Just watch it and see if it does it again. I don't think it will.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 08-31-2012, 07:46 PM   #3
Herk7769's Avatar
This can also be caused by driving during a heavy rain. The water can get in there and if the drain is not in the right place the accumulation of water can actually pull the cover down and after a while, completely off.
HAM CALLSIGN - KC3FFW
5th wheel
