Old 01-07-2017, 02:29 PM   #1
Upgrading Tires
I have the factory delivered/installed 16" E rated tires but would like to install the Goodyear Unisteel G614 RST. Anyone out there know whether or not the factory installed rims will handle a G rated tire? Tire pressure cold goes from 80# to 100#
ingalmi is offline   Reply With Quote
Old 01-07-2017, 02:53 PM   #2
rracer5's Avatar
Check the inside (backside) of your wheels. If aluminum, the wheel size & max PSI should be cast in one of the spokes (mine were).
BTW, I did upgrade to the G614's @ 100 lbs. My rims were rated at 110 psi.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-07-2017, 04:00 PM   #3
CaptnJohn's Avatar
Neighbors wheels were not. He went with Carlisle LR F rated and keeps them at 90#. I just sold the Trailer Kings to my tire dealer and bought 5 Carlisle 235/80R16 LRE just like on the last 5er.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 01-07-2017, 04:44 PM   #4
Thanks good info, I'll check my rims tomorrow hopefully rated for higher pressures
Old 01-08-2017, 01:51 PM   #5
Check the sailun s637 tires also. Great tire half the price.
2013 365 SAQ
Rufinit is offline   Reply With Quote
Old 01-15-2017, 07:22 PM   #6
BDavis's Avatar
I just went with the G614 on my 365SAQB. the factory wheels were 100psi rated. it is stamped on the inside. 2000miles on them so far. Love the confidence in knowing good tires are on the trailer.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 01-15-2017, 08:14 PM   #7
Nurek's Avatar
Sailun- made in China. Just sayin. I had some on my concrete mixer booster and they didn't even last 1 year before shredding apart and sidewall bulging. Pure garbage. The company tried to save some $ and it backfired on them.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 01-15-2017, 11:17 PM   #8
Airdale's Avatar
The Goodyear G614 LT235/85R16G at 3750# of load capacity is a very good upgrade for your trailer’s GAWR ratings. However, it will be expensive when done correctly. The steel cased G614 has a single rim size requirement, 6.5”. Most tires have a rim range, the steel cased 16” tires do not. The new rims need to be certified for the 3750# load capacity and 110 psi rating. Steel valve stems are also required.
Here is a reference to a typical rim for those tires. I have zero affiliation with this rim maker, it’s just a reference. Many others are made by other manufacturers.
TR8 | Sendel Wheels
Will the larger tire fit into the wheelwell? Will the distance between tires on the axles be adequate?
I don't normally recommend LT tires to replace ST tires. However, most G614 tires have an RST on their sidewall indicating they were manufactured for "Regional Service Trailer" applications.
A Trailer Tire Poster
Airdale is offline   Reply With Quote
Old 01-17-2017, 11:32 AM   #9
Wow you are the 1st person I have heard of that has had issues with the s637. I couldn't be happier.
2013 365 SAQ
Old 01-17-2017, 11:47 AM   #10
dannyabear's Avatar
That is exactly what I was going to post.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 01-17-2017, 12:12 PM   #11
alsdas88's Avatar
When I tried to upgrade my E rated tires last year to the Sailuns, A nationwide search found 0 availability in the sizes needed for my 340RK. Rumors were going around that Sailun was making changes at the factory and there was a shortage of supply.
I went for the more costly G614 G rated for my 5'r and could not be happier. Yes, they were more expensive, but what a difference from the Westlake E rated.
My rims are stamped for 110psi, but for some reason the previous owner replaced the factory tires with Westlake 80psi E rated tires.
Using the G614 G rated, my 5'r tows far better and I don't cringe during backing maneuvers watching those E rated tires fold over. Just did a 600 mile travel and couldn't be happier.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
alsdas88 is offline   Reply With Quote
tire, tires
