Old 01-09-2016, 10:04 PM   #1
00sandie's Avatar
Washing machine plumbing problem
Is there a water shut off for the washing machine connection in a sandpiper? My hot and cold lines are both leaking. Also any suggestions on reparing it. They are both leaking where the hose goes on to the valve. Click image for larger version
Name:	ImageUploadedByForest River Forums1452398629.318643.jpg
ID:	97560Click image for larger version
Name:	ImageUploadedByForest River Forums1452398650.008485.jpg
00sandie is offline   Reply With Quote
Old 01-09-2016, 10:20 PM   #2
KenHwy61's Avatar
Try cutting off the cinch clamps that are on currently and replace with screw drive type hose clamps. Hard to tell what fitting type in the picture but most RVs have braided tubing like you have incorrectly used with PEX fitting. This combination is prone to leaking because the braided tubing has a larger ID than PEX tubing and the cinch clamps used will only tighten to a pre-determined point. It is unlikely the factory would install any shut-offs valves although they are easy to add if desired.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 01-09-2016, 10:29 PM   #3
00sandie's Avatar
Thanks. I had been looking online how to repair it . Hopefully I can get it done.
Old 01-09-2016, 10:36 PM   #4
KenHwy61's Avatar
You can take a side cutter pliers and cut off the ear of the cinch clamp. Then you can pull it off. Then you can put on the hose clamp and tighten it up.
2012 Ram 2500HD CTD
Old 01-09-2016, 10:52 PM   #5
B47
Originally Posted by 00sandie View Post
Is there a water shut off for the washing machine connection in a sandpiper? My hot and cold lines are both leaking. Also any suggestions on reparing it. They are both leaking where the hose goes on to the valve. Attachment 97560Attachment 97561
In your first picture - it appears to me that the hose isn't fully pushed onto the valve.
Also - try repositioning both hoses further up on the valves and re-tightening the clamps.
Old 01-10-2016, 10:11 AM   #6
00sandie's Avatar
Thanks. I tried and I can't budge either one.
plumbing
