Old 11-05-2009, 06:47 PM   #1
water heater
we got a 2007 FR sandpiper bht and ever sence we got it the water heater run of propane but i was reading the owners manual and it says it can run on elektric as well but where or how do i switch to elektric,i got the 2 switches for the heatet tanks but nowhere else in the entire camper is a another switch does anybody has the same model or have any idea!!!!!!!thank you
armywife is offline   Reply With Quote
Old 11-05-2009, 07:12 PM   #2
Grape Escape
Electric switch is outside in water heater compartment. Hard to see normally black toggle switch which may have a safety pin thru it. We run ours strictly on hydro when available with no problems. Saves alot of propane. Just make sure it is switched off when not filled with water and connected to electricity as if it runs dry you will burn out electric heating element.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 11-05-2009, 07:28 PM   #3
oh thank you, from reading other posts i kind a got the idea it has something to do with outside,so just to make sure i turn my water heater off inside let all the water out and then switch (after i find it) it to elektric?ok i will go outside to check it out.thank you so much gonna safe me lots of money on propane.
Old 11-05-2009, 08:14 PM   #4
this is just great i looked for the owners manual for the water heater found it but the whole thing is in french the only reason i know its the right manual is because there is a hole bunch of pictures i guess for the non french speaking people,i mean im europaen but my french is by far not good enough to read a owners manual took english in school.thank you for the help tough.
Old 11-06-2009, 05:31 AM   #5
Grape Escape
No need to let the water out. Best to leave it full other than when winterising
Enjoy
Old 11-06-2009, 11:31 AM   #6
MtnGuy's Avatar
Definitely don't let all of the water out and then turn on the electric switch......you will immediately fry the element.
sandpiper
