Old 03-22-2014, 12:51 PM   #1
Water pump acting weird
My water pump is pumping, but not running smooth. I have a 365SAQ and cannot see how to get to the water pump easily. How do you get to it? Also, I read that I should check the water pump strainer. Where do I find this? I am concerned that I may be at the beginning of pump failure and I do not want that to happen. Thanks
chip gilbert is offline   Reply With Quote
Old 03-22-2014, 01:16 PM   #2
Ford Idaho's Avatar
https://www.google.com/search?q=rv+w...w=1242&bih=647
Old 03-22-2014, 02:09 PM   #3
TURBS's Avatar
define smooth ?
Old 03-22-2014, 02:54 PM   #4
water pump
Typically, a pump runs solidly and then stops when the pressure is met. my situation Is that the pump is running like a two cylinder engine that is missing on one cylinder. It seems to be going in and out, in and out. Then when the pressure is met, it will cut off and then on and then off and then on for a minute and then stops.
Old 03-24-2014, 11:46 AM   #5
golfmedik's Avatar
Sounds as if the pressure is being let off somehow. Have you checked for leaks everywhere? Even small ones? I believe the water pump is in the basement behind the back wall. No, it is not easy to get to. Especially when you wear XXL shirts!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-24-2014, 12:00 PM   #6
found it
I found it. It is where you said and somewhat of a tight fit. It does have a screen filter. It had a little trash in it. I was surprised that soo little trash was causing this. But it was, I am hopeful it is fixed. I was glad I went in there because there were some plumbing hoses up against the pump that I was able to tie up and away. Thanks for the feedback.
Old 03-24-2014, 07:22 PM   #7
jrobichaud's Avatar
How did U get in behind the wall? Is there an access panel?
jrobichaud is offline   Reply With Quote
Old 03-24-2014, 07:51 PM   #8
golfmedik's Avatar
Yes, in the pass through, the back wall has screws in it on the curb side that you take out and that panel comes out. Inverter, water pump, heat ducts, water heater and water lines are all back there.
Monty
Old 03-25-2014, 05:46 AM   #9
If all you want to do is get to the water pump then:
There are three screws on the wall to the left of the main water panel(across from the light on the forward wall). removing those three screws will allow the wall to come out and you can then reach behind the main panel to access the pump
pump, water, water pump
