Old 09-17-2011, 10:54 PM   #1
05 Dmax Dually's Avatar
Where is the fuel gauge?
I give up, I can not find the gauge for the fuel tank. I have a 05 sandpiper 38ft
05 Dmax Dually is offline   Reply With Quote
Old 09-17-2011, 11:37 PM   #2
bikendan's Avatar
unless you have a toyhauler, why would a 5th wheel or travel trailer have a fuel gauge?
Old 09-18-2011, 04:16 PM   #3
flyrotor's Avatar
If you are referring to the propane tanks, they don't have a gauge for them
flyrotor is offline   Reply With Quote
Old 09-18-2011, 06:30 PM   #4
RV Newbie
buzzards27's Avatar
Isn't there a propane level indicator on the control center? There might also be a dial gauge on the tank. Just check my Lexington and the is a dial on the tank AND a level indicator on the control center.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 09-18-2011, 06:59 PM   #5
flyrotor's Avatar
Most travel trailers have portable tanks, unlike the permanent mount tanks that mount horizontally.
With the portable tanks, I haven't personally seen any with a gauge.
Old 09-19-2011, 04:08 AM   #6
Sorry. It is a toy hauler and I was asking about the fuel station (gas pump). It does not have anything next to the control center, just a switch by the door to turn on the pump, witch does not work but thats for another day. I have looked what seams to be everyware and so did a friend. Nothing.
2005 Forest River 38ft Toy Hauler,
12ft garage
5500 wt gen
2 slides
Great Memories with Family
Old 09-19-2011, 07:13 AM   #7
Lottery Non-Winner
Ovair's Avatar
Does your 5th wheel also have a generator? If it does NOT, stop reading.
My previous rig was a 5th wheel toy hauler (different brand altogether though). It had a generator, and the fuel gauge for the generator was also the fuel gauge for the pump station. Next to the on off switch for the generator was another (unmarked switch) that was used to monitor the amount of fuel in the pump station tank. Alternatively, the generator may share the tank, in which case, the generator fuel gauge may be the one and only fuel gauge (switch not required). This is all dependent upon you even having a generator.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 09-19-2011, 09:50 AM   #8
Villa Estate 392FLFB
The_Stuff's Avatar
dad's toy hauler with fuel station and generator has no gauge.
One state/province at a time!
The_Stuff is offline   Reply With Quote
