Old 12-26-2013, 05:48 PM   #1
Steve & Phyllis
SteveBingham52's Avatar
Where is the pump?
Our 2012 Sandpiper 315re lets the fresh water tank fill up from the city water connection. It takes a day or so and I want to check the back flow valve on the pump but can't find the pump. I fear it is enclosed within the bottom cover and if so would like to start close to it if I drop a section. The dealers $99/hr is starting to look like a good deal but hope to fix it myself if possible. Thanks for any help.
SteveBingham52 is offline   Reply With Quote
Old 12-26-2013, 06:46 PM   #2
Ford Idaho's Avatar
Are you saying it takes a day or longer to fill your fresh water tank?
Old 12-26-2013, 06:47 PM   #3
Dave_Monica's Avatar
Have you run the water pump and traced the noise? I should be behind a removable panel in a lower cabinet inside or in the basement storage. If you have a docking station, it's probably right behind it.
Dave
Old 12-27-2013, 06:10 AM   #4
Steve & Phyllis
No it fills up by leaking back through the city water. Just can't locate the pump to check the back flow valve.
Old 12-31-2013, 08:31 PM   #5
cmptrkd's Avatar
Not sure if your Sandpiper has the "docking station" on the driver's side where all the connections for water sewer are, but if it does, your pump is right behind that, you can access it from the other side, there is probably 4 screws and a panel comes off. The pump will be right there. I hope this helps.
Loving our Sierra 365SAQ
Nights camped so far in 2016 = 0
Although Many trips scheduled.
cmptrkd is offline   Reply With Quote
Old 01-01-2014, 07:45 AM   #6
Steve & Phyllis
The panel to remove is it inside the camper? I do have a docking station.
Old 01-01-2014, 08:14 AM   #7
Yes inside. Youroo!!
Old 01-01-2014, 08:47 AM   #8
hrlyguy2's Avatar
Should have 4 screw to remove it.
It will be on the side of the dock station.
took awhile to find mine too.
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 01-01-2014, 09:38 AM   #9
cmptrkd's Avatar
Thought I better clarify just in case. The panel is inside the camper however, not inside the living quarters. It's inside the pass-through storage. Take just about everything out of your pass-through storage. Use a step stool and crawl inside the storage from the passenger side where you can go into the living quarters of the camper). This gives you access to get directly behind the docking station. Remove the screws, pull the panel away and there's your pump. There's quite a bot of room back there in my 365. I think I'm going to put a 5 gallon pressure tank in mine this spring. Hope this helps.
Old 01-01-2014, 11:22 AM   #10
Steve & Phyllis
Thanks all. Will go look if weather clears up this week. Only in the 40's so a little cold to be playing around water.
