Old 11-05-2016, 05:14 AM   #1
2017 401 flx Sat. pre-wiring
I was wondering if the directv box needs to be connected in the bedroom as there does not seem to be any way to connect it in the living room? If so, will it also work on the living room tv?
dcavaiani is offline   Reply With Quote
Old 11-05-2016, 11:41 AM   #2
I see connections behind the mounted Hisense flat screen
How do I get the Hisense to release from its mount so I can pull it out to get at the connections behind it in the living room??
Old 11-06-2016, 11:12 PM   #3
chop249's Avatar
Reach behind it in the middle, you should feel a strap. Pull down on that strap and the tv should pull out.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 21/18 = 11
chop249 is offline   Reply With Quote
Old 11-07-2016, 05:42 AM   #4
Thank you
So simple !
Old 11-18-2016, 06:48 PM   #5
1 cable 2 Directv boxes
I have one long cable running from the dish on a tree to the pre-wired satellite system input on the outside of the camper Satellite connection, and into the controller located at the camper living room (working fine). I have Directv working on that 1 controller I have there now.
If I put a second controller in the bedroom and connect it to the inside pre-wired satellite jack in the bedroom, will I be able to see Directv in the bedroom as well, and will I be able to separately control the stations between the two Directv controllers?
wiring
