Old 05-12-2016, 02:37 PM   #41
AquaMan's Avatar
He's not talking, now that he's riding up top on the dash!
2016 Georgetown 364TS
Nights Camped 2017 - 16
AquaMan is online now   Reply With Quote
Old 08-31-2016, 02:12 PM   #42
So it's been a year since my frame was repaired/reinforced and I just wanted to post a final follow up.....
The trailer handles better on the road and interior cargo doesn't shift like it used to. The trailer tracks straight and doesn't get blown around. It no longer feels like it is lumbering along behind as much as it is 'flowing' with the truck. The frame modifications made as much difference as swapping the axles; having the two jobs done literally translated into a 200% improvement in ride quality and handling; seat of the pants sure, but very noticeable nonetheless.
If you're not into welding additional cross-members into your frame I strongly urge anyone with one of these big units to look at MORryde's crossmember kit which basically does the same thing:
Performance Crossmembers by MORryde - MORryde Products
The way my trailer is now with the frame supports gussets, added crossmembers, and 7K axles..... this is how this trailer should have been built if it was truly intended to be a traveler. The factory build as far as I'm concerned is designed for seasonal use only, not a traveler.
2013 Forest River Sierra 365SAQ, 7000# Axle Swap, 5th Airborne Air Ride
2010 Chevy 2500HD D/A, CC, Timbrens, Curt Q16 Slider
Nights Camped in 2015 -- 40
Nights Camped in 2016 -- 26
cfisher523 is offline   Reply With Quote
Old 08-31-2016, 03:06 PM   #43
2007 WildCat 32QBBS
05CrewDually's Avatar
It's funny this comes up. I'm putting a steel order together now to add crossmembers to tie in the spring mounts.
Your last sentence above is exactly what I think to myself all the time.
05CrewDually is offline   Reply With Quote
Old 09-01-2016, 08:33 PM   #44
Lippert fixed ours over the winter and I had it aligned at a truck chassis shop. The axles where not bent but the alignment was out some and they fixed that.
The welder that was sent said he was fixing them all over the country for Lippert. I just cannot figure out how it is worth it to them to send them out on the road that way when $100 dollars in steel would have built it write at the factory.
Well ours to pulls good no more swaying all over the road handle nice better than new now.
Jscribner is offline   Reply With Quote
365, 365saq, axle, bent, frame
