Old 07-17-2013, 04:27 PM   #1
fishgolf365's Avatar
365SAQ. Keeping cool in hot weather
Anybody got any hints on keeping the entire coach cool during periods of temps on the 90's. I have tried several things and have had good results, but wondering what everyone else is doing. We have 2 A/C's and both are ducted.
fishgolf365 is offline   Reply With Quote
Old 07-17-2013, 05:00 PM   #2
I took the last vent off in front and back run and put a stop at the end of each.they both blew on past the last vent and into ceiling.That increased airflow dramatically.We also have two a/c units and have no problem keeping it 72 degrees when in 90s.As long as its been cooling since morning.
Rtazz17 is offline   Reply With Quote
Old 07-17-2013, 08:00 PM   #3
How difficult was it to close the duct off at each end. If possible give me some info so I can close each of them off. No need to put cool air where I don't need it.
Old 07-18-2013, 09:04 AM   #4
I just took cardboard and that silver duct tape and closed off endcaps... Took 5 min... Makes huge difference..
Old 07-18-2013, 09:52 AM   #5
Did you just take the last round vent out on each end to access the duct and block it just past the vent? If so it sounds easy enough. Thanks.
Old 07-18-2013, 09:58 AM   #6
Exactly... Bunk room u will notice it the most... It will be much cooler in there
Old 07-18-2013, 11:12 AM   #7
Great. Thanks, I will do it this evening.
Old 07-19-2013, 12:24 AM   #8
fishgolf365 let us know if it works easy for you too and helps with the cooling. I'm going to have to check this on our camper too. I never think it gets cool enough, except at night.
Grandma camping with the kids and grandkids
(I bought the RV, so they have to let me camp)
2014 Sandpiper 376BHOK 5th Wheel (Picked up 5/6/13 from RV Wholesalers)
2006 Chevy Silverado 2500 Crew Cab 4x4 Diesel with airbags added (pulls great)
B&W Companion Hitch
Nitecat is offline   Reply With Quote
Old 07-19-2013, 05:13 AM   #9
I believe they are all built this way.My brother has the same camper and he found the same thing.
Old 07-19-2013, 10:15 AM   #10
golfmedik's Avatar
We stayed in Myrtle Beach last week in the mid 90s and kept the rig in the low 70s by running both a/cs. However, with mine being a '12 and only having one factory vent in the bunkroom, I cut the ceiling and installed another in that duct line. I then bought a closeable vent and installed it in the 1/2 bath(and closed it almost off) and it made a huge difference over last year.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
