Old 10-26-2018, 07:09 PM   #1
366FL Hydraulic Cutting Out...help!
Two hydraulic slides and front landing jacks keep cutting out. We have to keep clicking the button over and over until they finally extend.
Think its a switch or solenoid?
jb4xx is offline   Reply With Quote
Old 10-27-2018, 09:07 PM   #2
How long does it run before it stops? Theres also a breaker that trips but resets as well.
brad2388 is offline   Reply With Quote
Old 10-27-2018, 09:13 PM   #3
NMWildcat's Avatar
I had the same exact problem a few weeks ago. For me it was the auto reset fuse(s). Was two of them connected by a bus bar. Was between the battery and the hydraulic motor. Works like new now.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 10-27-2018, 09:25 PM   #4
Is it the breaker? I think there is two of them. Where did you buy yours?
Old 10-27-2018, 09:28 PM   #5
If its cold outside i believe its normal. But you need to check to make sure it was a 50 amp breaker. I believe some came with the wrong size.
Old 10-27-2018, 09:29 PM   #6
Is this it?Click image for larger version
Old 10-27-2018, 09:29 PM   #7
Thats not it.
Heres the letter from lippert on it.
https://www.lci1.com/assets/content/...ulic_Pumps.pdf
Old 10-27-2018, 09:31 PM   #8
Originally Posted by brad2388 View Post
Thats not it.
Heres the upgraded 80 amp breaker.
Bussmann CB185-80 Waterproof High Amp Flush Mount Type III (3) Circuit Breaker (80 Amp), 1 Pack https://www.amazon.com/dp/B001PTBVLW..._u9r1BbTD6D4QY
Old 10-27-2018, 10:33 PM   #9
NMWildcat's Avatar
This is what the two of mine look like. They are connected by a copper strip in my setup. 50amp 12v auto reset circuit breaker. Can get them at any auto parts store. $12-$15.
hydraulic
