Old 09-29-2019, 12:45 PM   #1
384QBOK w/One Control - individual slide outs?
Hello,
New owners here w/a 2018 384QBOK. We have the One Control touch screen system for all of our electronics. I can not figure out how the hell to put out the slides INDIVIDUALLY. When I go to slides in the system, it opens/closes them in order, but all of them. How can I pick and choose if I want to open say just one slide?
Thanks for the help!
Oceanlvr78 is offline   Reply With Quote
Old 09-30-2019, 05:16 AM   #2
I have an 08 38 ft bunkhouse and mine is same way, one switch opens all 3 one at a time. Iíve looked and havenít found anything on doing 1 at a time
dodgemark is offline   Reply With Quote
Old 10-05-2019, 12:07 AM   #3
Coach
Assuming not much has changed with the hydraulic system itself, it's a single pump/flow system. Ours runs off a rocker switch, but still works the same as you describe. One switch opens/closes all the slides with no individual select. An option would be to install shut offs in your hydraulic bay that would allow you to isolate individual slides.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
slide, slide out
