Old 03-06-2016, 08:58 PM   #21
rvpartime's Avatar
I don't remember for sure but I think when connected to shore power, the invertor light would come on. When running on just batteries, the light wouldn't come on nor the refrig would work.
When we had walk through, the camper was connected to shore power.
rvpartime is offline   Reply With Quote
Old 03-06-2016, 11:09 PM   #22
Tom48's Avatar
Originally Posted by kasedian View Post
Attachment 101188
Ok. I I switched off the shore power. The lights work. The refrigerator stayed on. The only things that didn't come on, were the television and the ceiling fan. I checked voltage on the two cables in the pic, and had 12v dc across the two. So I'm guessing that it does not hook up to the batteries.
377FLIK
I thought you had said Converter +- but the picture says INVERTER so I would suspect between the marking and large wire gauge that it is a hook up point to install an optional INVERTER perhaps for folks who would order with a Residential Frig
Tom48 is offline   Reply With Quote
Old 03-07-2016, 03:50 PM   #23
A few questions about my new 377FLIK
Ok. I hooked up the cables to the batteries. Can't really tell if it made a difference or not. I have two batteries that are paralleled together. I have a set of cables labeled "battery pos" & "battery neg" that were already hooked to the batteries. I hooked up the cables labeled "inverter pos" & " inverter neg" to the batteries as well. Everything works just the same as it did before. I turned off shore power. The inverter is still on. The 120v refrigerator is still on too. Just as it was, before I hooked up the cables. I'm still stumped on what they feed, or where they feed from. Can any of you guys look at your FLIK, and see if you have these cables in your battery compartment? Wumba? rvpartime?
Thanks.
377FLIK
kasedian is offline   Reply With Quote
Old 03-07-2016, 04:18 PM   #24
rvpartime's Avatar
As I have posted, they are in mine but had to be connected before invertor would work. I will be following post to see outcome. Enjoy your 377 FLIK./
