Old 08-03-2018, 01:11 AM   #1
Add heat register in basement
I have a 2016 Sierra 355 re. What I want to do is cut a hole in the basement floor and add a vent off of the heater to warm the underbelly. My question is where to cut the hole in the basement floor. Thanks in advance.
Okiefatman is offline   Reply With Quote
Old 08-03-2018, 04:34 AM   #2
Oaklevel's Avatar
My first question is why?
I am assuming that you do a lot of below freezing camping???
If not it would not be necessary. Personally I think that you will be adding a mouse highway into the living space.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-06-2018, 01:56 AM   #3
I will be spending the winter in Oklahoma trying to keep the underbelly warm. Not possible for mice to get into basement it is sealed up to the frame everywhere, I did that myself. I don`t want to drill though into the top of a holding tank, there is four tanks down there.
Old 08-08-2018, 08:15 PM   #4
spaach's Avatar
The furnace access is through the basement wall in most of these trailers. All you should need is a duct collar, a register of your liking, (I would get one you can open and close to get the desired flow), and some 4" heater duct. I would put it high in the section of the wall that is not normally removed for service. High so your stuff does not block it.
spaach is offline   Reply With Quote
Old 08-08-2018, 08:19 PM   #5
spaach's Avatar
Sorry, I missed the belly part. Our 343rsok has a 1.5" duct that is stuffed into one of the tank vent openings from the factory.
