Old 01-03-2015, 11:30 PM   #1
Adding a receiver to a Sierra F295RK to pull a boat
Has anyone ever installed a rear 2" receiver on their 5th wheel Sierra F295rk in order to also pull a boat?
ssskdm is offline   Reply With Quote
Old 01-04-2015, 12:03 AM   #2
Denver, CO
garbonz's Avatar
If it is not there already, I would say NOT. There are lots of threads here about that and other rear bumper topics. Many of the rear bumpers on these rigs are not designed for strength.
2017 Fuse 23T
Old 01-13-2015, 09:30 AM   #3
Depending on the state, you may not be allowed to tow double trailers. Check with DMV!
dkelly is offline   Reply With Quote
Old 01-13-2015, 11:46 AM   #4
TGR
TGR's Avatar
You should contact your dealer and find out which welding shop they recommend. Just adding a receiver to the bumper will not work. However, there are several important considerations before you move ahead.
Considerations:
  • Adding a hitch will likely void your frame warranty. Any problems that would have anything to do with pulling a trailer behind your rig will no longer be covered. If you are out of warranty, then it’s all on you anyway.
  • Many states do not permit pulling a trailer behind a 5th wheel. States that do have overall length restrictions from 65’ to 70’ overall and there are time-of-day restrictions in some areas.
  • There are horror stories about all kinds of problems with towing a trailer from bent frames to cracked walls.
    I’ve seen many people towing trailers behind their 5th wheelers and a few friends who do as well. It is done all the time without anything unusual happening. I don’t know how frequent owners of your rig do this but your dealer might know. My dealer was very helpful to people who wished to tow a boat behind their 5th wheel and directing them to a welding shop that added additional support as they would do this to used rigs no longer under warranty.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
295, boat, sierra
