Old 04-05-2014, 07:14 PM   #1
KB3MMX's Avatar
adding Coleman Digital Thermostat to 355QBQ
I'm looking at upgrading to a more accurate digital thermostat in our unit.
Can anyone help me with which Coleman Digital model I need to order?
Thanks !!
_
-Forest River Sierra 355QBQ Bunkhouse
-2007 Duramax/Allison Stage 2 Garrett Turbo W/ KB3MMX EFIlive custom tuning & lots of other goodies...
KB3MMX is offline   Reply With Quote
Old 04-11-2014, 07:20 PM   #2
KB3MMX's Avatar
Bump for any help on the correct model number to order.....?
Old 04-11-2014, 07:24 PM   #3
Todouble's Avatar
What kind of heat do you have? Propane?
Heat pump?
Todouble is offline   Reply With Quote
Old 04-11-2014, 07:41 PM   #4
KB3MMX's Avatar
Standard propane furnace for now
Old 04-11-2014, 08:09 PM   #5
Todouble's Avatar
Is this what you have?
Old 04-11-2014, 08:11 PM   #6
Todouble's Avatar
Name:   ImageUploadedByForest River Forums1397265113.126395.jpg
Old 04-11-2014, 08:56 PM   #7
KB3MMX's Avatar
No, ours is the standard mechanical style currently.
I want to upgrade to a digital one like in the pic...but when I looked online, there is more than one Coleman Digital model available.
Does it matter or are they all wired the same?
Old 04-12-2014, 04:11 AM   #8
Todouble's Avatar
Most are all the same. Just make sure it's not for a heat pump.
Old 04-12-2014, 05:39 AM   #9
Witch Doctor's Avatar
x'2 any a/c heat stat will work, just mark your wires from what terminal you take them off of. It takes 4 wires, some have 5 wire the extra wire is for the high low fan speed on most. You might get that option. There are some threads that people have added a toggle switch to take care of that. Me I never run the fan on high just to noisy for me. But that's just me.... If you need help in wiring it in PM me I did HVAC granted it was a while ago, but I'm sure I could help you still.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
thermostat
