Old 06-06-2016, 03:27 PM   #1
Antenna Booster Switch
I've got a Sierra 377FLIK and now I need to locate the antenna booster switch. Apparently they turned it off at the dealer while doing warranty work. Also, I've got a Hisense TV that I don't have a clue about the wiring and I can't get it off the wall. It was wired incorrectly when I first got it but my ex-husband to be pulled out all the wiring for the satellite including my TV wiring....ugh. Anyone have any suggestions?
Dimomma is offline   Reply With Quote
Old 06-06-2016, 03:47 PM   #2
It's in the bedroom on the side of the dresser (right side as your looking at it). As for the TV, lol, this is a trick, but can be done. In the rear there are 4 screws with washers attached. Your going to need to forcibly, and I mean forcibly, push up on the tv until they reach the top of the "tracks" that they are in. The top of the tracks have a wider opening than the washers, hence what holds them in the tracks. Once I got mine out, I loosened the screws a bit, so now it is a breeze to get it out. They WAY overtighten them at the factory. be patient, it took me and a service guy about 20 minutes to get it done. Start by working it one side at a time. Good Luck!
Wumba is offline   Reply With Quote
Old 06-09-2016, 08:11 AM   #3
Thanks!
Thanks! I found it after calling the dealer. Weird stuff.
Old 06-09-2016, 08:19 AM   #4
Flybob's Avatar
If you store the trailer without being plugged in or using a battery disconnect switch, you should turn the tv amp switch off as it will drain the battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
antenna
