Old 02-01-2016, 04:05 PM   #11
Jerry01's Avatar
Before I installed two 6 volt batteries, we had one group 24. Prior to our trip I had the battery on a charger at home just to make sure it was charged. Installed the day before to get the fridge going. The next day when we went to leave, I went to raise the landing gear and I got a beep and a low voltage indication. Plugged into the truck for about 20 minutes and was able to hitch up. Drove for about 6 hours to the campground then unhitched and tried to auto level. Partway through for a beep and a low voltage indication again. Plugged into shore power and all was good. Two points; one group 24 is nowhere near acceptable for auto leveling. The second is that we never blew a fuse, just got the low voltage indication. The wires for the batteries are 4 gauge though. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 02-02-2016, 03:57 PM   #12
When I took delivery of my Sierra, my level up system power for the controller was hook into the hydraulic pump when I raised or lower landing gear it would blow fuse. I wired up a dedicated power supply from battery to the controller haven't had any issues since I did this. Don't know if this would help with your issues or not but Lippert recommends a dedicated power supply to controller with 10 amp fuse.
Matt & Sondra
2016 Sierra 377flik
2003 F350 6.0 Powerstroke
Curt Q20 hitch
k8mlp is offline   Reply With Quote
Old 02-02-2016, 06:52 PM   #13
Anyway you could post a pic of that? I'd like to show that to the service rep when I drop it off. Also, any contact info at Lippert that recommended that fix? Thanks!
Wumba is offline   Reply With Quote
Old 02-02-2016, 07:19 PM   #14
Witch Doctor's Avatar
Call Lippert, and tell them to email you the correct way it needs to be hooked into, they really are pretty good to deal with that i have found, not to happy with some products but good CS I have found. Worth a try...Good Luck and safe travels.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-02-2016, 08:07 PM   #15
Level_Up_Troubleshooting_Guide.pdf
This is level up trouble shooting guide pdf it has diagrams may be of some help.
Matt & Sondra
2016 Sierra 377flik
Curt Q20 hitch
