Old 08-02-2014, 04:48 PM   #51
5erDriver's Avatar
They used the same hangers. The wheels are 'Sumec', nice looking wheel, and the tires are 'Westlake'
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 08-02-2014, 05:53 PM   #52
golfmedik's Avatar
Hangars are the same. Wheels are different due to 8 lugs instead of 6 and I had my own Goodyear tires.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 08-02-2014, 06:53 PM   #53
I have different rims when they replaced mine. But yes 8 lugs from six. Mastertrac tiresClick image for larger version
Name:	ImageUploadedByForest River Forums1407023577.393323.jpg
tromler is offline   Reply With Quote
Old 08-03-2014, 01:09 AM   #54
rbcdp98's Avatar
I was told that whole 20% rule. But once I weighed my unit and my axle weight was 11,700 empty this was way too close for my liking. I then weighed my unit packed for only a weekend trip and no water. I was at 11,920. When I started taking to FR I emailed them both cat scale weight slips and it still took over a year to get them changed out.
rbcdp98 is offline   Reply With Quote
Old 08-03-2014, 09:37 PM   #55
What tire rating and what psi are you running in your tires? Dropped mine off at the shop today. Waiting to hear this week what will be done.
chiro is offline   Reply With Quote
Old 08-03-2014, 09:45 PM   #56
golfmedik's Avatar
Most run E rated tires at 80 psi...I have G rated on mine at 110psi. To run 110 psi tires, you have to have a wheel that is rated for that pressure. Should be stamped on back of wheels. Plus 110 psi tires/wheels have to have metal valve stems.
Old 08-03-2014, 09:59 PM   #57
What brand g rated tires are you using. I am purchasing a set of used rims from a friend that have metal stims and are 110 psi rated. He is taking them off his heartland that is 9 months old. He is moving up to 17.5 rims and tires to get more cushin on his tires.
Old 08-04-2014, 03:38 AM   #58
golfmedik's Avatar
I am running the Goodyear G614's on mine. Lots of people are now going with the Sailun 637..found here Sailun Tire
It has the same load capacity as the GY, but lots cheaper. It is a China made tire, but the factory has met all of the US mandates and specs for tires. The ONLY Chinese company to do so.
Old 08-06-2014, 08:46 AM   #59
Helmsey's Avatar
Attachment 59546
This is the same setup they gave me. I looked at the wheels and with the screw in valve stem they are good to 200PSI, that was a nice surprise.
2015 Chevy 3500HD
Helmsey is offline   Reply With Quote
Old 08-10-2014, 06:56 PM   #60
Mine were changed out last yr but my rim is different and tire as well. I think its a crap shoot what you will get but either way they are 7k axles.
Rtazz17 is offline   Reply With Quote
365, 365 saq, axle
