Old 03-31-2016, 08:33 PM   #1
steph45601's Avatar
Battery drain
When you have no shore power and your fiver is stored for a while how do you not drain the battery? We flipped the main breaker but the Co monitor is still on and so is the power to the sound bar. There is a battery disconnect in one of the compartments but it doesn't seem to do anything that I can figure. We are taking the camper in for warranty work and want to have everything properly shut down so the battery doesn't die for the deal
Ed. There has to be something I don't know. Never had this with our MH.
steph45601 is offline   Reply With Quote
Old 03-31-2016, 08:34 PM   #2
steph45601's Avatar
I guess I should've mentioned we have a 2016 Sierra 371 REBH
Name:   ImageUploadedByForest River Forums1459474466.622468.jpg
Old 03-31-2016, 09:05 PM   #3
SeaDog's Avatar
Removing the rig from shore power and switching the battery disconnect off should remove all power from the rig.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-31-2016, 10:41 PM   #4
denali15's Avatar
Battery drain
The battery disconnect only turns off / disconnects the inverter and not power to the unit. This was confirmed with FR engineers.
I installed a separate disconnect on the batteries. This way I can totally turn the power off to the unit.
Name:	ImageUploadedByForest River Forums1459482057.068185.jpg
denali15 is offline   Reply With Quote
Old 04-04-2016, 02:15 PM   #5
I always pull my battery out completely when j bring it in for warranty since it is usually there for a while in the winter. I keep it on a trickle charger. When the dealer needs to open the slides they use a jump box or spare battery to do the work they need.
PSEYFRIED is offline   Reply With Quote
Old 04-24-2017, 08:32 AM   #6
I have the same problem with my 2016 Sierra. Appears as if the built-in battery switch only cuts of the inverter. After several weeks of being in storage, my battery's are completely discharged. I like the battery cut off switch you installed however I hesitate to do this because of its effect on the six point leveling system. In my old 5th Wheel Cougar, if the battery was disconnected, I'd receive an RF Jack error which indicates a power failure. My question is, on the Forest River units, in my case a Sierra, does a battery disconnect affect the leveling system (memory)?
Thanks.
Mikep-sc is offline   Reply With Quote
Old 04-24-2017, 07:04 PM   #7
chop249's Avatar
Thanks.
Are you referring to the return to start with auto level? I've found that even with the return to start I always have to adjust to get the correct hitching height. I wouldn't worry about it and put the disconnect in. I have the switch, I just need to make time to go get the cables I need to finish the install.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 21/18 = 11
chop249 is offline   Reply With Quote
Old 04-25-2017, 06:19 AM   #8
Appreciate your response Chop249. I'll install a battery disconnect on the neutral side of the battery and I'm sure that will put.this issue to rest. As far as the LCI Leveling System is concerned, in my old Cougar, whenever I disconnected the battery or it went dead, I'd receive an error message on the Leveling Panel to that effect. I had to reset the unit by dropping all the jacks at least 9" to allow the automatic leveling function to work. Not a big deal, by a pain. Was just wondering if this was the case on my 2016 Sierra. I'll soon find out when this disconnect is installed. Thanks again for your advice. Much appreciated.
Old 04-25-2017, 06:24 AM   #9
Attachment 103513
LOOK at your picture. You have hot wired items not controlled by the disconnect switch - Those will drain. Move them to the other side of the disconnect switch. RV manufacturers have them there for Liability & Lawyer reasons, they don't care if you drain.
270S is offline   Reply With Quote
Old 04-25-2017, 09:36 AM   #10
FR engineering confirmed that completely cutting off battery current will not have an effect on the leveling system. They stated the RF Jack... error I received with my old unit was indicative of a trying to operate the system with a low voltage (battery almost discharged) condition and not a total battery disconnect.
battery, drain
