Old 07-19-2018, 05:58 AM   #1
jrobichaud's Avatar
Bent gray water pull
The design of where he forward gray water tank pull is under the water filter. The filter blew off a couple times as it wasnít seated properly. Thus bending the open/close rod. Now the gray water is stuck in open position. Does anyone know how difficult it is to replace the valve handle?
jrobichaud is offline   Reply With Quote
Old 07-19-2018, 06:48 AM   #2
RSchleder's Avatar
Is the "bottom" of your RV enclosed? If so, you'll simply need to either drop the material covering the bottom, or cut holes in it, (not my recommendation) and trace the cable from the handle to the valve. Once you determine the length of cable you can purchase a replacement cable and install it to correct the problem.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-19-2018, 07:08 AM   #3
Is your valve a Cable push/pull type or the T handle? Youroo!!
Old 07-21-2018, 02:44 PM   #4
jrobichaud's Avatar
Itís a push pull
Old 04-05-2019, 09:54 PM   #5
Those damm water filter housings. Mine popped of and took out the summer/winter Valve. Itís usually because itís not seated all the way. I Replaced the whole assembly and the valve. The newer style locks in better. To be safe do not pressurize without a filter I it.
quick83 is offline   Reply With Quote
bent, water
