Old 07-10-2015, 10:53 AM   #1
robertc68's Avatar
Broken black tank drain valve/cable
Well my front black tank ,the valve is broken in the open position,not sure if it's a broken cable or the valve itself.I was wondering how hard it is to replace one ? I don't really want to take it in and have to wait for months.
It has has been broken for a while but since its in the open position I added another valve on the end where the hose hooks up. It was poorly installed from the factory,the cable (which I hope it is )was routed to tightly.
2012,365 Saq.Sierra
2004 F350 DWR.
robertc68 is offline   Reply With Quote
Old 07-10-2015, 12:48 PM   #2
Not to hard. Pull the Coroplast under the trailer and locate the valve. See if you can manually operate it. If its the cable order and replace just the cable. If its the valve you may be able to just remove the screws and slide in a new one.
I had to cut my 1 1/2" grey pipe and put a rubber connection in to replace the valve but now it will be easier down the road to repair.
Sierra360PDEK is offline   Reply With Quote
Old 07-11-2015, 08:11 PM   #3
supercab79's Avatar
The gate was cracked in half on mine from the install at the factory someone while putting the valve in used a large screwdriver to push the flanges apart and went a little crazy and busted the paddle/gate right in half causing it to not only be half open but also jammed it in position. Thank god I checked it before we ever used the tank. The install was not impossible but not fun either. I was also about to cut the pipe myself but it went in on the last try. Good luck... however cutting the pipe inline on one side would definitely make life easier...
Marc
06 3500 Laramie Dodge Mega Cab 4x4 5.9CTD Short Bed Dually
13 Sandpiper 365SAQ Fifth Wheel
05 Chevrolet Tahoe
93 F-250 XLT 4x4 Diesel Banks Sidewinder (gone but not forgotten)
79 Jeep CJ-7
77 F-250 Crew Cab Short Bed 4x4
supercab79 is offline   Reply With Quote
black, black tank, drain, tank
