Old 10-08-2012, 03:16 AM   #1
robertc68's Avatar
bunk lights and fantastic fan not working
My bunk lights( all 4) and fantastic fan are not working.I have looked at the fuses,breakers and gfi,which are all on,however when I checked them with a multi meter there is no power to them.I have no clue,the plugs and ceiling lights work.Its like there is another cutoff some place.Does anybody have and idea,I have been trying ti figure it out for 5 days. Thanks..
robertc68 is offline   Reply With Quote
Old 10-08-2012, 09:14 AM   #2
Road-King's Avatar
Your bunk lights and Fantastic fan should all be 12 volt. So you need to look at your 12 volt power supply. There should be a breaker somewhere near the battery, follow the positive wire coming from the battery to find it. You should be able to reset it.
If that's not it your next step is the converter. Do these lights and fan work when hooked up to shore power? The converter is the same unit inside your TT that holds your breakers and fuses.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 10-08-2012, 12:22 PM   #3
Dave_Monica's Avatar
You've only mentioned bunk lights and Fantastic fan, so I'm assuming that other 12V lighting is working. You need to check your 12V fuses on your power center. Don't assume that if you don't see a red LED light (indicating a blown fuse) that all is well. The panel fuses should be identified...try a new fuse.
Dave
Old 10-08-2012, 12:28 PM   #4
robertc68's Avatar
Yes I have checked every fuse.the main lights are working just the fan and bunk that will not come on.
Old 10-08-2012, 12:37 PM   #5
Road-King's Avatar
Are you hooked to shore power?
Russ & Kim
2014 Alpine 3600RS
Old 10-08-2012, 12:55 PM   #6
Are the fan and the bunk lights identified as the same circuit or separate circuits? Have you checked for loose connections at the 12V fuse panel?
Dave
Old 10-08-2012, 04:10 PM   #7
robertc68's Avatar
Even with shore power,they will not work.Basically the fan was running,I stepped away for a few minutes when I came back it was off. Totally lost,I checked the fuse by the battery its fine.
Old 10-08-2012, 04:18 PM   #8
robertc68's Avatar
Dave
not sure if they are on the same circuit,my fuse panel does not label the fans.
Old 10-08-2012, 04:22 PM   #9
Don't know if this will help but there are ALOT of fuses behind the main control board too. I know remote ones are hidden there as well but maybe it's back there. If you haven't solved the problem , send me a PM and I will give you a suggestion that worked for me when my converter blew.
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
Beausdog is offline   Reply With Quote
fan
