Old 10-20-2013, 09:31 AM   #11
wilem's Avatar
Because he said he couldn't find it not that it didn't have one. The cable has to tee off somewhere for set 2. It may be where it splits he will find the issue. Or if he doesn't have one where the cables hook up to the splitter / wall plate with or without a booster.
And all 10,000 I have seen have boosters. Mine was hidden under a ledge. My last camper it was Hidden in a cabinet .
wilem is offline   Reply With Quote
Old 10-20-2013, 09:39 AM   #12
Some RVs have Magnadyne switch box instead. I don't think this one does from the specs.
Find the coax connection on the back of your TV and follow the wire to the wall. It should be plugged into the booster control plate. Perhaps it's behind the TV? It looks about like this:
If you have a TV in the bedroom it may be with that TV instead, so do the same thing in that room (follow the wire).
Old 10-20-2013, 09:39 AM   #13
Herk7769's Avatar
Might have to look inside cabinets, behind the TV, or some other location.
Most (but not all) manufacturers use a tiny black button to switch the camper's TV feed from roof to cable.
The Winegard ones look like:
ID:	41426   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 10-20-2013, 09:40 AM   #14
Ford Idaho's Avatar
Old 10-30-2013, 01:27 PM   #15
It's in the master bedroom right next the light switch. I have the same model.
JRRoden is offline   Reply With Quote
Old 10-30-2013, 08:32 PM   #16
5erDriver's Avatar
We have a 2013 Sandpiper 365saq. The whole cable/satellite setup and jacks were miss wired. Took me a while but after some hair pulling, opening cover plates and taking off some access panels in the storage I got it up and running. Cable to the bunk room was via satellite output and vise versa throughout. I abandoned the satellite completely and just wired cable to all cable jacks. Feel bad for someone who maybe isn't handy and would have to return to dealer to get sorted. Thank goodness that's the only problem we've had in it in. You may want to try connecting the campground cable to the satellite input in the docking station and try tuning your tv like normal. It could be that simple that they are wired to the wrong input. Start with the living room cause its the shortest run to the docking station. I'm sure they are just reverse wired. I had to methodically go through all the jacks and try tuning. Then swapping the coax behind the plate to figure it all out. Fine now tho. Good luck with it.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
mpg
