Old 06-27-2015, 11:56 AM   #1
Can someone tell me what air conditioning units are in a sierra 5th wheel-330rls
330rls
Garry waller is offline   Reply With Quote
Old 08-05-2015, 07:05 AM   #2
I have a 355QBQ and it came with one 13,500 Dometic. I added a 15,000 Dometic. Is that the info you were looking for?
OKI Marine is offline   Reply With Quote
Old 08-07-2015, 12:59 PM   #3
Thanks for replying Okl marine. Could you also tell me is that a good size unit. We have 2 units in our sierra. One for the main part of the fifth-wheel and a smaller 1 in the bedroom. The one in the bedroom does fine but the other one can't get the area below 84 when it's in the high 90's outside.
Old 08-10-2015, 12:06 PM   #4
I have a 2015 366fl and it came with two units one 13000btu in the bed room and one 15000btu in the main living area, its been in the 90's for the past couple weeks here in Virginia with high humidity. They work alot but keep the place 69 -70 no problem.
phil22652 is offline   Reply With Quote
Old 08-10-2015, 12:12 PM   #5
I matched mine up to the same brand as the one that came with the camper. However, I went with the bigger unit to add because it wasn't much more in price and just incase the other should stop working while we are out camping then I have a more powerful unit to cool
Old 08-11-2015, 09:32 AM   #6
I have 2 15,000btu units and have no problem keeping the temp at ~72F even when it is 95F outside.
2015 Siera 377FLIK
2014 Ford F350 KR
Maggie the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
stevewise is offline   Reply With Quote
Old 08-11-2015, 12:42 PM   #7
Thankyou everyone for your comments.
Old 08-11-2015, 01:41 PM   #8
Up to 38 or so feet, a 15,000 in the back and 13,000 in the BR should adequately cool if you can use them both at the same time on 50a service.
phillyg is offline   Reply With Quote
Old 08-12-2015, 08:35 PM   #9
360PDEK with a 15000 and a 13500 and have no issues keeping our fiver cold. Are your units ducted together? If so set your bedroom unit to a much lower temp and that will help push more cold air to the back. Also, pull your end vents and stuff a towel or insulation just past the vents. A lot of air goes past those vents and this made a bid difference in air flow in our unit.
Sierra360PDEK is offline   Reply With Quote
Old 08-12-2015, 08:56 PM   #10
scootingranny's Avatar
We just camped for four days in 100+ temps in Texas and after the first two days we realized that about 10am we needed to turn on both ac units (15000 in main area, 13500 in bedroom) and it would keep cool at 76-78 in both rooms. At night we would turn off the bedroom ac and run just the main room one as we aren't used to cold temps at night (we keep home unit at 78-80). Our unit is 40' long with ceilings that aren't low (not sure exact height). Our friends with a V-lite kept theirs so cold for him that she had to use an electric blanket at night. Theirs is 30', I think with lower ceilings but that's just not comfortable for us. We had 11 people over one night playing a dice game called LCR and it was very cool and comfortable (of course it was at night).
I just know that you need to keep it moderately cool at all times for the ac units to work adequately. If the rv gets hot inside, it takes a long time to cool down, at least for us.
2015 Coachmen Chaparral 360 IBL
2014 Ram 3500 Turbo Diesel 6.7 4wd Crew Cab Dually
scootingranny is offline   Reply With Quote
Old 08-19-2015, 08:20 AM   #11
ok355re's Avatar
We are living in our 355re in Oklahoma I noticed when the temp outside would get into the 90s the living room ac would have a hard time keeping camper cool. I discovered that both ac units have a place where you can open and the air goes straight down and not through the ducts. This keeps the camper cool even in the 100s.
Ron and Dorothy
Milky Way the boss
2014 Sierra 355RE
2005 F350 Powerstroke
ok355re is offline   Reply With Quote
Old 08-19-2015, 08:23 AM   #12
Sometimes when it is really hot out, I will open a vent fan in the rear of the camper and use a small drum fan with a high cfm to keep things moving.
5th wheel, sierra, wheel, air conditioner
