Old 01-31-2014, 05:40 PM   #11
Camping Buddys's Avatar
Thanks a lot 5erDriver! I guess there's always a first time (scare) to drill in the fiberglass!
DW ok'd the purchase, we're heading tomorrow to camping world to get it.
(and they have a great sale too)
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
http://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 01-31-2014, 06:15 PM   #12
I don't recommend leaving the electric awning out 24-7 all season long unless you have old coots poles as noted above.
That being said I had a non-electric canopy 19 on the old trailer with the center and side supports engaged and locked to the ground. Along came a strong wind, knocking the roof portion of the support (anti-sag) out of the hole in the roller tube and through the awning. Yup nice Big hole there! On the good side it was the search for a new awning that got me a knew Trailer instead!....Love that Ebay!
Warm weather ahead....er somewhere....
David 01 is offline   Reply With Quote
Old 01-31-2014, 06:25 PM   #13
jrobichaud's Avatar
Thanks for the tip on the poles and never thought of the center support cutting into the awning. I sent a note to OC about a set of poles.
jrobichaud is offline   Reply With Quote
Old 01-31-2014, 06:38 PM   #14
Originally Posted by Camping Buddys View Post
Greetings guys! if you don't mind me asking, was the center support easy to do?
mine is starting to sag already in the center. Thanks for your help!
Most of the F/R units are (Bonded Sides) very THIN skin.Also finding a Stud in the proper location for your support is not Guaranteed. I used a 6x6 stainless plate with (2) fasteners at the top,right under the drip rail,and two rivet fasteners on the bottom. I then mounted the (cradle support) to this plate. That assures a solid base for the cradle assy. Youroo!!
youroo is online now   Reply With Quote
Old 01-31-2014, 07:02 PM   #15
5erDriver's Avatar
Yes. Agreed. The cradle I got from camping world includes a steel backer plate if you wish to use it. It is Dometic
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 01-31-2014, 07:06 PM   #16
5erDriver's Avatar
Yeh. The Dometic cradle from CW comes with a metal backer plate and rivets if you choose to use it
Old 01-31-2014, 07:40 PM   #17
tumbleweed1's Avatar
After reading this I think I'll get an awning support too!
Sent from my LG-E980 using Forest River Forums mobile app
2014 Siearra 355RE
Dodge 35000
tumbleweed1 is offline   Reply With Quote
Old 01-31-2014, 07:43 PM   #18
jrobichaud's Avatar
Great idea tumbleweed. I have had campers for 15 years and always installed on. The 21' awnings need the support. Plus, unfortunately they don't make em like they used to
Old 02-01-2014, 07:48 PM   #19
Went to Camping World today and bought one.
2014 Siearra 355RE
Dodge 35000
Old 02-02-2014, 01:42 AM   #20
jrobichaud's Avatar
Good luck w install tumbleweed. Should be fairly straight forward install for you. Feel free to send pics of your finished job.
awning
