Old 09-03-2018, 08:16 AM   #1
buddyu's Avatar
Control Panel
All icons except one has disappeared on the control panel. We cannot retract the awning, check tank levels, etc. Even my phone app now has a blank screen. Has anyone had this happen? If so how can we correct this? Not good on Labor Day weekend!
buddyu is offline   Reply With Quote
Old 09-03-2018, 08:33 AM   #2
PPST Wannabe
kenandterry's Avatar
Pictures are best. What year, make model of rig have you got?
What brand of control panel?
We need help to help you.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-03-2018, 08:46 AM   #3
buddyu's Avatar
Itís a 2019 Sierra 379 FLOK. The control panel is a LCI. Iíll take a picture of the tablet when I get back later. Sure hope you can help.
Old 09-03-2018, 09:05 AM   #4
Icons
Hello, most of the time just rebooting the control panel will fix any problems. It might take a couple of reboots though. Also, using the battery disconnect switch to reboot 12v system helps too. I've heard of people having issues with the actual connections to the panel coming loose or damaged. Hopefully that's not your case.
Hope this helps
JoePK is offline   Reply With Quote
Old 09-03-2018, 12:53 PM   #5
buddyu's Avatar
All is well now. I turned the battery disconnect switch on and monitor is now working. On my MH when we were connected to shore power we turned the disconnect switch off. Does that hold true for a 5th wheel?
Old 09-03-2018, 01:05 PM   #6
Retired and Loving Life!
Alan F's Avatar
Send a message via MSN to Alan F
On my Motorhome, I leave the disconnect in the ON position when I am connected to shore power. Recharged the batteries and I can run 12v appliances.
Alan F is offline   Reply With Quote
Old 09-03-2018, 01:14 PM   #7
buddyu's Avatar
Thanks Alan. That is good to know. We disconnect because we assumed it would overcharge the house batteries when we had our Georgetown.
