Old 03-12-2012, 07:22 PM   #1
De-winterizing?
Temps here are so nice, we are going to head out this week. My question/concern, should I de-winterize? I have the Sierra 355QBQ, it has a covered underbelly and heaters. Will it be ok, if/when it does dip below freezing? Or should I wait and just bring some jugs of water for use?
2011 Sierra 355 QBQ
04 Ford F350 V10
blatch70 is offline   Reply With Quote
Old 03-12-2012, 07:54 PM   #2
TURBS's Avatar
honestly but only my opinion unless its below zero for a few days you would not have a problem .
20 degrees for 8 hours and the 60' during the day I would trust myself .
ultimately you need to be the judge
Old 03-14-2012, 09:48 AM   #3
3 Happy Campers's Avatar
I do not actually winterize my unit until the first week of Jan each year. During Oct, Nov & Dec I just drain the lines/tanks & leave all faucets open between uses.
I also un-winterized in the beginning of March every year.
I run beach through the lines, flush a second time with fresh water, drain the lines & tanks & again leave all faucets open.
Never had a problem over 20 yrs & four campers.
We’ll be heading out for the first trip of the year next week.
If you follow this you should really not have a problem even if the temps drop for a short period of time.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
de-winterize, sierra, furnace
