Old 11-19-2013, 09:20 AM   #1
Dinette Slide Issue
I just bought a 2007 Sierra with triple slide. When extending the slides bedroom and bunkhouse extend fine. When the couch/table slide starts going out it jumps and makes loud noise like it is catching on something. Any idea what my issue is?
jnort is offline   Reply With Quote
Old 11-19-2013, 11:36 AM   #2
Dave_Monica's Avatar
Welcome to the forums!
It would help to tell us if your slide drive is electric or hydraulic. Have you looked under the couch/dinette slide room for obvious damage tohe drive components or slide room floor?
Dave
Old 11-19-2013, 02:21 PM   #3
It is hydraulic. I have looked under it while it is extended. It has a gear and a gear trac that look good. No broken teeth. I haven't taken the under belly off to look underneath the trailer while it is going in. How easy is it for them to come off track or alignment? Sorry, first time fifth wheel owner.
Old 11-19-2013, 02:21 PM   #4
No damage to floor on inside of trailer.
Old 11-19-2013, 03:14 PM   #5
Originally Posted by jnort View Post
It is hydraulic. I have looked under it while it is extended. It has a gear and a gear trac that look good. No broken teeth...
Hydraulic with a gear & track? Is it a hydraulic motor turning the gear? Bit confused.
Old 11-19-2013, 03:18 PM   #6
Here's a link to Lippert's site for manuals on your slide... Through Frame Slide Service Selection
I guess it'll be a 2 or 2.5" 'through the frame', the difference being whether it has 1 or 2 hydraulic pistons. Should help you to trouble-shoot the problem.
Dave
Old 11-19-2013, 03:26 PM   #7
Looks like they use the gear/cross-shaft to keep the room aligned regardless whether there's a electric or hydraulic actuator.
Dave
Old 11-19-2013, 05:34 PM   #8
There is only one push rod and it appears the gear system is supposed to keep it aligned. However one time putting the slide out, the back of the slide was six inches from being out completely when the slide stopped. I brought it back in and It came in all the way and since has gone out all the way. Putting the slide in and out is just not smooth. I am hesitant to even try it again fearing I will do some damage.
Old 11-19-2013, 05:49 PM   #9
Ford Idaho's Avatar
Have you lubed the tracks/guides?
A little silicone lube did wonders for the main slide on my trailer.
Old 11-19-2013, 05:55 PM   #10
Thanks. That will be my next attempt to fix it versus diving in and losing nuts and bolts. That is a little intimidating.
slide
