05-10-2017, 04:07 PM
Electrical outlet troubles
I have a 2015 Sierra 385FKBH. I lost power to all outlets except ones labeled gfci. The GFCI that has reset button is fine also. No breakers tripped and have power coming in as advertised. Besides outlets I lost power to living room ceiling fan at the same time. I shut the camper up after the weekend with everything working and came back next weekend and had these issues. Any ideas would be appreciated. Has anyone had luck finding electrical schematics online before, not having much luck myself.
05-10-2017, 04:10 PM
Should be a reset button on gfci outlet that works . Push that , you'll hear it click and your in business.
MARINOS
2015 PRIME TIME AVENGER 28 DBS
2016 GMC SIERRA DENALI 2500 HD
05-10-2017, 04:12 PM
Thanks, but as I said in the post that is fine. No issues there.
05-10-2017, 04:17 PM
The problem has to be in a junction box or loose wire somewhere. Having trouble locating junction boxes because underbelly is closed that is why I would like to get my eyes on a schematic. Breaker/fuse panel is fine as well as the converter.
05-10-2017, 04:19 PM
You have 50 amp service, did you check that both hot legs are powered?
Joe
2015 Wildwood 27RKSS (now sold)
2015 Silverado 2500HD Duramax
05-10-2017, 04:20 PM
Yes, both legs are good.
05-10-2017, 04:30 PM
You may have 2 GFCI's . Check outside outlets or others near sink. Larger units usually have more than one. Is the ceiling Fan AC or 12V?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-10-2017, 04:40 PM
I will check closer when I get to the camper this weekend. The one outside and by the sink both have GFCI stickers on them but no buttons. These three outlets that are GFCI protected are the only ones I can use right now. They have power. I forgot to mention that the fidge outlet quit also but I ran an extension cord to outlet by the kitchen sink and fridge works fine on that outlet. Microwave also works. I am unsure of the ceiling fan until I get there, I don't have books here either. Thanks!
05-10-2017, 05:16 PM
The GFCI outlets are wired such that one GFCI unit will protect several down the line and are controlled by the test / reset buttons on the master. The downstream outlets are protected by the one unit. Check the fridge outlet as some fridge outlets are GFCI masters.
TST Tire Monitors
2 100W solar panels
05-10-2017, 05:38 PM
Thank you for your help. I have checked the fridge one also. Unless I am missing one somewhere all GFCI outlets work. Fridge one is not identified as GFCI protected but I did check that. I think I need to get my hands on the wiring schematic.
05-10-2017, 05:50 PM
Check the connections of the branch circuits at breakers and bars in the power center. On our Rockwood they over tightened all the connections stripping out the heads and smashed the actual conductors flat as a pancake. The slightest movement of a wire caused them to break loose. I had to replace all the breakers and find new neutral and ground bars due to the stripped screws.
05-10-2017, 06:02 PM
Thanks. I think that has been checked also but I will double check.
05-10-2017, 10:19 PM
Just as confused as you
It's funny that nobody mentions that you will not find a schematic for FR products.
Richard & Jill
05-10-2017, 11:10 PM
Is the outside outlet ok? Do you have an outside kitchen with an outlet?
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
05-10-2017, 11:40 PM
Can you follow wiring from an outlet that does not work to one that does or back to breakers? Not easy in all rigs but I can figure out where most of mine go by pulling a few screws.
I am betting MR Havencamp is correct. You would have to take the breakers out to see this most likely.
I would also pull the GFCI. Sometimes they fail and only circuits after it no longer work.
05-19-2017, 06:13 AM
How did this turn out?
MARINOS
