Old 01-05-2014, 04:52 PM   #1
cmptrkd's Avatar
Fantastic Fan in kitchen 365SAQ
I have been thinking of adding a Fantastic Fan to my 365SAQ in the kitchen / living room area. There is already a roof vent in this area and I guess one of the options available was to have a fantastic or equivivent fan installed during the build.
My questions are, has anyone added a fan and if so, what model? Was the wiring already in place and running down to the panel where the switch is to be located? My panel has a blank in the spot for the kitchen fan, so I know it will be easy to add the switch, I think the hardest part will be getting the wiring installed.
Thanks for any help and or suggestions.
Loving our Sierra 365SAQ
Nights camped so far in 2016 = 0
Although Many trips scheduled.
cmptrkd is offline   Reply With Quote
Old 01-05-2014, 05:16 PM   #2
TURBS's Avatar
Albeit a little different scenario I added a fantastic fan to my bedroom.
I just used the ceiling light wiring which already existed and use the light switch to turn it on and off.
Easy for me I could turn the lights on and off manually as I can reach them.
There most likely only be wiring in the ceiling for lights so if you want them separate you'll have to run new wires.
I would add another switch so you can run the fan in either direction.
Here's my roof install.
TURBS
golf cart safety instructor.
ID:	44546   Click image for larger version
Old 02-04-2014, 01:49 AM   #3
jrobichaud's Avatar
You have some options. Look at fantastic fan website. They have several models to choose.
For those of you that want to upgrade your fantastic fan.
look at campers world website they sell a fantastic fan upgrade kit for existing fantastic fans. They say it fits every model which has the automatic opener and remote. This would work good for the some/fan which is so high in the kitchen.
I agree the wires should be up there. The fan switch in mine is located to the left of the thermostat so if FR pre wired for the fan, the wires may already be in the ceiling.
jrobichaud is offline   Reply With Quote
365, 365saq, fan
