Old 03-04-2015, 03:49 PM   #1
Mojojojo's Avatar
Gap in the floor
So I had the side compartment open and used the master bathroom and found light coming in the bottom of the wall at the floor..... Never seen issues like this before anyone else have this issue ,is it common, do I need to worry about a larger problem?
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 03-04-2015, 04:33 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Make & model? What does the inside look like. It appears as if the floor is buckling or lifting up. Is the inside covered by carpet or molding? Can you (Inside) peel it back and inspect? Take a lot of pics they do help.
donanddona is offline   Reply With Quote
Old 03-04-2015, 04:48 PM   #3
Mojojojo's Avatar
That's linoleum floor with a trim piece the wall is not flush against the floor.Click image for larger version
With flash
Old 03-04-2015, 04:52 PM   #4
Mojojojo's Avatar
Under the floor picture is sideways so the water lines are into the ceiling of the crawl space
Old 03-04-2015, 04:52 PM   #5
donanddona's Avatar
Did you mean sheet vinyl? Looks like the tile is separating.
Old 03-04-2015, 04:53 PM   #6
Mojojojo's Avatar
Make in signature but it's a 2011 sierra 355QBQ
Old 03-04-2015, 04:56 PM   #7
donanddona's Avatar
Consider one of three. First I would consider increasing the floor molding to seal any gaps. Second replace or add additional seal in the compartment space. Third is it possible their is water damage that caused the floor to warp like that?
Old 03-04-2015, 05:01 PM   #8
Mojojojo's Avatar
Sheet vinyl linoleum what ever the whole floor is covered in in one piece....
My phone only lets me do one pic at a time sorry
Old 03-04-2015, 05:03 PM   #9
Mojojojo's Avatar
And I know my square is rusted but it's old
Old 03-04-2015, 05:06 PM   #10
Mojojojo's Avatar
It's actually the wall that isn't flush the floor is fine the aluminum bracket in the under storage I'm not sure if it is stock or aftermarket but the wall is flush where the under screws are and slightly open where they aren't...... No water damage I can see but would explain why the bathroom is so much colder if the door is left closed.
Old 03-04-2015, 05:38 PM   #11
donanddona's Avatar
Ii looks as if the manufacture used a faulty wall. It does not appear to be square/straight (cut). If not covered by warranty then I would attempt to repair myself after validating the floor/wall is not damp/wet. One, I would seal the gap and then increase the quarter round at the floor. Then do a light test again.
Old 03-04-2015, 05:48 PM   #12
Mojojojo's Avatar
That's the repair route I was thinking silicone it good top and bottom the wall and all look good nothing is wet, it appears that the lack of a screw in the middle of the angle aluminum may have let the wall settle out a little it's tight were the screws are
Old 03-04-2015, 07:51 PM   #13
I had s similar issue with my 366 FL in the living room. The dealer went in from the basement and siliconed the gaps from underneath.
Sierra360PDEK is offline   Reply With Quote
Old 03-04-2015, 08:37 PM   #14
Mojojojo's Avatar
So no structural problems with yours then? Do you still own it? We intend on keeping this one for at least another 10 years it's only 4 yrs old and we own it outright no loan no lean
Old 03-05-2015, 07:59 AM   #15
No structural issues found just was not a tight fit. We traded it for a 360 PDEK, the front living room just wasn't filling our needs.
