Old 09-11-2017, 11:59 AM   #1
Generator size?
What brand and size wattage you are using for your fifth wheel with dual ac units. I have a Honda 3000iu quite. Does great job only run one ac unit.
sierra daddy is offline   Reply With Quote
Old 09-15-2017, 12:28 PM   #2
Generator
I would use a 5500 watt diesel that should be sufficient. Start the units one at a time.
Okiefatman is offline   Reply With Quote
Old 09-15-2017, 01:12 PM   #3
bikendan's Avatar
Will you be running it in a campground?
Old 09-15-2017, 02:16 PM   #4
Blog: RVroadtripper.com
hbillsmith's Avatar
Check out Microair Easystart
MicroAir
hbillsmith is offline   Reply With Quote
Old 09-15-2017, 02:19 PM   #5
Insert witty title here
Whatever you get, make sure it's an inverting type and NOT one of those open frame gennys commonly sold in home improvement stores. They are LOUD and will quickly get you really disliked by all your camping neighbors.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 09-15-2017, 02:24 PM   #6
This question has to be answered first.
You can go a whole different route if you will never use it in a campground or someplace where noise would bother someone.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 09-15-2017, 02:42 PM   #7
Old Camping Squid
Eagle-751's Avatar
Honda EU200i, Only as a backup, we are setup full time and hardly ever use the A/C ( never with the generator). It more for the winter time camping when we really need the furnace.
Larry Collins { PM }
2006 F150 Supercab 5.4 Flex Fuel
2017 H-D FLHTK Ultra Limited
EZgo TXT and ClubCar Precedent golf carts
2009 Forest River Salem 30QBSS
U.S. Navy Veteran
Eagle-751 is offline   Reply With Quote
Old 09-24-2017, 12:48 PM   #8
I don't need generator while at the campgrounds I stay at they all have 50 amp hook up service... this is only out in the woods... the 3000 iu is doing great so far just run extremely hard with ac is running.... other than that it's fine would like to find one that will run both ac unit at the same time
Old 09-24-2017, 12:52 PM   #9
SeaDog's Avatar
If you plan to run two AC's and other things like microwave then you need at least 5500 watts your choice of fuel to run them.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-24-2017, 01:05 PM   #10
rsdata's Avatar
I would think that the biggest problem with larger watt generators would be the size and weight and how to transport them... maybe if you have a toy hauler that would make it easier to heft them around... ortherwise you may opt for another 3500 watt unit and wire the second AC to a separate plug to extend to that generator or parallel two units
2014 Shamrock 183
Old 09-24-2017, 01:14 PM   #11
Thought about that but it's double the hassle and double the gas when you take both of them...
Old 10-21-2017, 03:17 PM   #12
So harbor freight has a bigger on that you can go buy.. Descent price for a genny for the woods and no one around.. also you can buy one at Sam`s at a good price that uses propane or gas, I`m not sure on the size though.. good luck
divers6926 is offline   Reply With Quote
generator
