Old 02-02-2014, 02:48 AM   #1
jrobichaud's Avatar
Hydraulic birds nest
I haven't had my pdi yet but have asked the dealer to tend to this (see pic).
The wires and hydraulic hoses and valves look like a birds nest. They are I. The front utility compartment under the front room. The unit has hydraulic front landing gear. Not sure of the slides are also hydraulic or electric. It seems to me the factory could have made this look neater. Does anyone else's hydraulic lines look this way? (2014 365 saq)Click image for larger version
Name:	ImageUploadedByForest River Forums1391327286.352736.jpg
jrobichaud is offline   Reply With Quote
Old 02-02-2014, 04:50 AM   #2
PhotoMaster's Avatar
When I get my 30DS back I'll check it.
I don't recall it looking that jumbled.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 02-02-2014, 06:51 AM   #3
AquaMan's Avatar
You have hydraulic slides. I also don't recall mine being that messy, at least I've never made note of it ever being an issue if it is. I think the wires make it look messy, maybe just tie them up a bit.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 02-02-2014, 07:31 AM   #4
jrobichaud's Avatar
That's what I asked the dealer to do, use some zip ties or something.
Old 02-02-2014, 11:21 AM   #5
rracer5's Avatar
That assembler should be re-trained, reassigned or fired! Is that hydraulic valve "hanging" loose also?!! Definitly get them to re-route the hydraulic lines and mount the valve securely. If your slides are hydraulic, there may be a time when you may need to isolate one slide or another from opening or closing and you would need to turn a portion of that valve off. If you start twisting the valves' knobs, you can be stressing the lines and fittings.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-02-2014, 11:49 AM   #6
jrobichaud's Avatar
Thanks rracer. Agree the assemble must have gone on break and forgot to finish the job. Yes the valve body is hanging free. I have asked dealer to sort it out ill sent a pic of the finished product
hydraulic
