02-02-2016, 06:00 PM
Hydraulic pump resettable fuse location
I need help locating my resettable fuse/breaker for my hydraulic pump. I don't see it near the pump which is where it was on my old fiver. FR says it is block with two fuses and a grey resettable fuse near the pump. My dealer says it look like a breaker. Last night I looked over the entire area and do not see it. Anyone have any suggestions or a picture of what I'm looking for. My fiver is a 2015 Sierra 360 PDEK.
Thanks for the help.
Camp on.
02-02-2016, 06:03 PM
Look along the sidewall next to battery. There should be a copper strip with a positive feed and breakers bolted to it. The breaker should have a reset button on it. Mine were automatic and just had to wait about 20 secs for it to reset.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
02-02-2016, 06:09 PM
Something like this is what you'll be looking for. Push the small button on the side to reset
02-02-2016, 06:21 PM
Is this it? This is the only block near the battery and pump.
02-02-2016, 06:24 PM
I don't think that is it. Do you see a copper buss mounted to the wall anywhere?
02-02-2016, 06:51 PM
It could look something like this. Thanks Turbs for running out into the cold to snap this pic. 😀
02-02-2016, 07:01 PM
Yw Tim, anything for you!
As Tim said it'll likely be by your batteries.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
02-02-2016, 07:24 PM
I think I found it. Looking straight on it is hard to see the fuses. Now, can I pick up a new one at an auto parts house? Is there amperage rating that I need?
02-02-2016, 07:26 PM
Look for a little black button on the side of it. Just push it back in.
02-02-2016, 07:56 PM
It's an auto reset. My slides go in a foot or two and the breaker trips then resets. Takes 3-4 times to bring in the slides. It has been progressively worse over the past several months. FR said the fuses go bad and need to be replaced. Of course they won't sell me one.
I really appreciate your help Aquaman. Thanks for taking time to help me with this.
02-02-2016, 08:02 PM
Most likely it is a 20amp breaker. The dealer installed a 40 amp breaker and I never had the problem again. You can get these at auto parts stores, hardware stores, online. Probably about $5.00
02-02-2016, 08:04 PM
02-02-2016, 08:12 PM
Originally Posted by AquaMan
Yep that's it replace it with a 40 amp, had the same problem bought an automatic 40 amp ended my problem...
Coachmen M/H
Concord
2018 / 300 DSC
02-02-2016, 08:13 PM
Just ordered two. Thanks again Aquaman. Happy camping.
02-02-2016, 08:29 PM
02-03-2016, 06:40 PM
Camp on.
I have a Sierra 376BHOK and the copper block with 2 /50 amp circuit breakers is in the side door where hyd. pump on the back wall and has a black plastic flap to cover the fuse bar my dealer shop forman told me there is supposed 2 fuses to run the hyd. and another for something else.
he told me to put a screw driver across the terminals and push the sw. if it worked the fuse is burnt out those hyd he said draw approx. 80amp. and just 1 fuse isn't enough so i always have a sec. one added so i don't have anymore trouble. you can add a fuse to the bar and use a 6ga. jumper on the other side. no more bad fuses.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
02-06-2016, 06:04 PM
New breakers came in today and I replaced the old one. I was surprised to see the old was a 50amp. The new one is a 40amp but worked great. Slides went in and out several times without stopping. I have an extra breaker just in case I ever need it.
Thanks again for the help.
02-06-2016, 06:23 PM
Left Coast
Ordered 4 40 amp....
