Old 10-07-2017, 08:45 PM   #1
Inverter location
We just purchased a 2016 sierra 381rbok. Does anyone know where the inveter is located?
whitewinghunter is offline   Reply With Quote
Old 10-08-2017, 02:07 AM   #2
Always Learning
My apologies if you know the following, but...
It's hard to say- you might or might not have an inverter.
Most campers come with a converter- this generally charges your battery and will make 12v out of 120v electric.
Fewer campers come with an inverter- this will make 120v electric out of 12v.
The ones that do come with an inverter are typically those with residential refrigerators.
Are you sure you should have an INverter?
Old 10-08-2017, 04:42 AM   #3
I have a switch labeled inverter and I have a residential referg. So yes pretty sure i have one, just haven't found it yet but haven't looked to much. Thanks
Old 10-08-2017, 05:11 AM   #4
Always Learning
Heh, fair enough. There's just often confusion around the two devices. Similar names, similar purposes.
So that said- no idea where it would be. My guess is up near the batteries. At least, that's where it *should* be from a technical perspective.
Sorry I can't help me. Good luck!
Old 10-08-2017, 03:29 PM   #5
spaach's Avatar
It should be behind the false wall in your storage bay. Unscrew the wall between your storage area and stairs. It along with the rest of the systems should be be in that area.
spaach is offline   Reply With Quote
Old 10-09-2017, 08:04 AM   #6
Thank you . I will be pulling that out just to verify it is in there. That makes since because the fuse panel is very nearby.
Old 12-28-2017, 03:22 AM   #7
Jeff6146's Avatar
Mine is behind the false wall under the coat/boot closet in the floor. The closet is right at the front door on the right
Jeff6146 is offline   Reply With Quote
cat, inverter, location
