Old 07-11-2015, 07:42 AM   #41
Originally Posted by elind View Post
Turbs, This is my spare mounted between the landing gear. The tire extends out front and the JT Strong arms won't clear it.
ps tilt you head to the left.
I have the spare located exactly as yours in addition with a undercarriage sliding drawer unit about 33" back from the landing gear. Did you ever mount the JT Strongarm stabilizers on your unit? How did you determine the location for mounting? Pictures? Where did you relocate the spare at/to?
OKI Marine is offline   Reply With Quote
Old 07-11-2015, 07:54 AM   #42
Phat Phrog Stunt Crew
elind's Avatar
I moved my winch back so the front hole of the winch is now where the back hole is. But in order to do this I added a 6" X18" plate to mount the winch onto it. The new location had nothing to mount it on. Look at my signature to find my pics to my mount.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 07-13-2015, 02:50 PM   #43
Ok. For all that have mounted these. The distance in between my front landing gear is 72 1/2" When positioning the brackets for the front two bars between them, do I split the difference and mint them in the middle at 36 1/4 or do I measure over 30" from each one. I am assuming that the front side bars are to be the same distance as the two in the front. Does anyone know? I called Lippert the manufacturing company and couldn't get an adequate answer. Any comments would be appreciated.
Old 07-13-2015, 06:56 PM   #44
Witch Doctor's Avatar
As far as I know they are centered. both front and rear. At least mine were. Unless you go from back to front on the rear which I think is better. But they installed mine both to the center front and back. Per instructions.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-13-2015, 07:15 PM   #45
elind's Avatar
The front arms will meet in the center with the two hole plate. I suggest the other arms go forward or to the rear at 30". Otherwise you need a cross member installed to attach the rear arms to the center.
2014 Wildcat 327ck
Old 07-13-2015, 07:27 PM   #46
Even with the distance being greater than 72" ? I have seen the two in the back go both ways. I've read the instructions and they mentioned splitting it if it were 58" and they also mentioned as close to 30" as possible. That's what confused me.
Old 07-13-2015, 07:49 PM   #47
elind's Avatar
There are different sets of arms made for different landing gear widths. Were the instructions generic?
2014 Wildcat 327ck
Old 07-13-2015, 07:51 PM   #48
They are the instructions that Lippert sent to me via an email
Old 07-13-2015, 08:31 PM   #49
elind's Avatar
Are all the arms the same length or are the front ones different lengths? Will they extend enough to reach the center.
2014 Wildcat 327ck
Old 07-13-2015, 09:40 PM   #50
Yes, same length. Should be long enough to reach the center. I will go with what you suggested. You've done it and it works. Thanks for your help.
