Old 06-15-2014, 07:43 PM   #1
jrobichaud's Avatar
JT strongarm
My 365saq has the hydraulic front landing gear. I ordered the JT strong arm kit. The installation video I watched was set up for the non hydraulic landing gear. Does anyone know how these strongarm swill attach to the landing gear? Is there a kit I should also order? Thanks for the assistance!
jrobichaud is offline   Reply With Quote
Old 06-15-2014, 07:47 PM   #2
dcheatwood's Avatar
I had both on my wildcat but have sold it now. Miss the hydraulic landing gear now. So much faster than elec. Hope you find what you're looking for.
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
Old 06-16-2014, 12:07 PM   #3
Helmsey's Avatar
I have the BAL version for our 365 and so far I don't have them installed on the front for the same reason. On this 5er though I haven't noticed that much movement up front so I'm not terribly worried about them. Most of our shake was in the rears and adding the BAL loacl arms there really took care of it.
With that said, if there is a way to put them on the front I will look into it. Another issue you might run into is the spare tire getting in the way. On mine, the spare tire is right at the front underneath the camper and at a quick glance think it might create an issue with the bars.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 06-16-2014, 12:42 PM   #4
dcheatwood's Avatar
You may be able to see below in the 2 pics that I had strongarm on my wildcat with hydraulics landing gear. They worked fine. Is there an issue with your particular unit?
Old 06-16-2014, 03:24 PM   #5
Sierra Rep
you wont need the JT strongarm for hydraulic legs. those are for electric jacks. they hydraulic legs are pitched out to 14 degress to help the unit more stable accoring to lippert who makes the legs.
Sierra14 is offline   Reply With Quote
Old 06-16-2014, 03:46 PM   #6
Plain Old Member
Uh. Hydraulic legs move a lot too. I can testify to that, we live in one with the level up system. Lippert does make a weld on tab just for the JT Strongarms. I don't have a link at my fingertips right now though. I'll look it up. I'm just going to make my own weld on tabs and stabilizers.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-16-2014, 03:47 PM   #7
Plain Old Member
Here you go:
JT's Strong Arm™ Jack Stabilizer Adaptor Lug for Hydraulic Fifth Wheel Landing Gear Legs – Lippert Components, Inc Online Store
Old 06-16-2014, 06:51 PM   #8
I have a 365 saq with hydraulic front legs and the power legs in the back. I have the steadyfast stabilization system and haven't been impressed with it. I have talked to the owner of steadfast and he wants me to take off the rear power jacks and put manual crank down jacks. I have also chalked the wheels with x chalks and regular chalks and the camper still moves.
Any thoughts on how to stop the camper from shaking?? I think its the equiflex suspension.
chiro is offline   Reply With Quote
Old 06-18-2014, 11:16 AM   #9
Helmsey's Avatar
The legs are round instead of square, no holes like the traditional landing gear.
2015 Chevy 3500HD
Old 06-18-2014, 11:30 AM   #10
AquaMan's Avatar
I use a tripod up front, x-chocks, and rear stab and there is still a noticable "shake" when we travel camp. When I set up at our seasonal site, I put a set of jack stands behind and in front of each wheel. What a difference! Virtually all shake is gone.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 06-18-2014, 03:35 PM   #11
Thank you aqua man. I have a set of sissor jacks I will try next time I go out.
I think the equiflex suspension I have on it causes a lot of problems with the motion in the 5er.
Old 06-18-2014, 03:41 PM   #12
TURBS's Avatar
I might have to disagree on the equiflex.
Bouncy movement would be more in "springs" and "rubber" tires.
Jmtc
Old 06-18-2014, 11:37 PM   #13
Dangeri's Avatar
I have a 2014 365SAQ and I have hydraulic jacks on the front and the electric jacks on the back . I installed JT's last year and try work awesome . In addition I have the x chalks and I have next to no movement. I was able to install with all items that came in the box. I will take some pics this weekend.
Dangeri is offline   Reply With Quote
Old 06-18-2014, 11:45 PM   #14
SKnight's Avatar
Mine seems good as is but I came from an entry level TT. That thing shook if you scratched your nose.
But I would like to say woo hoo, we have a factory Sierra rep now!
Old 06-19-2014, 03:08 AM   #15
Witch Doctor's Avatar
x's 2 I debated getting the auto ground control system 3.0 put on by lippard at the rally. I chose electric 4 point system after talking with the factory. They said they would not install my JT's on hydraulic system do to the offset. but I could still use them on the front landing gear only with electric. The 2nd set mounted behind the rear wheels are at a 14 degree angle and can not be mounted. But in essence I really do not need them there because I will still have the rear stab. left on and that's where they are hooked to now. Why did the factory tell me no? yet they sell them on the big foot? VERY STRANGE......
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-19-2014, 06:33 AM   #16
Phat Phrog Stunt Crew
elind's Avatar
I have a problem with my Wildcat and JT Strongs in the front. My spare tire is under the landing gear blocking the arms placement. I could relocate the spare to the back bumper but it's nice under the rig. Would I get got results with a tripod in the front and JT Strongs on the rear stabs?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 06-19-2014, 06:37 AM   #17
TURBS's Avatar
Elind,
You can still put them on with spare in place.
Look at mine.
ID:	55729   Click image for larger version
ID:	55730   Click image for larger version
ID:	55731   Click image for larger version
Old 06-19-2014, 06:43 AM   #18
TURBS's Avatar
Don't quote me but I think last year if you bought a set at the rally they would install them for you!
Old 06-19-2014, 06:51 AM   #19
elind's Avatar
My spare lays flat under and sticks out the front a few inches under the front door.
2014 Wildcat 327ck
Old 06-19-2014, 07:06 AM   #20
TURBS's Avatar
Pictures?
