Old 01-31-2014, 09:50 AM   #1
Keyless door entry
Our 2014 376BHOK came with one & no directions. Help
Moonlighting is offline   Reply With Quote
Old 01-31-2014, 08:35 PM   #2
tumbleweed1's Avatar
We just got ours a week ago and no code. The book said one code but wouldn't work. Called the dealer and the factory code is different from the one in the book. If you touch the keys it won't work right so we put our hand to cover it without touching it. It works off the static off your hand. After you cover the numbers it will light up. Then enter the code then lock button. The code we got was 3715 factory code.
Sent from my LG-E980 using Forest River Forums mobile app
2014 Siearra 355RE
Dodge 35000
tumbleweed1 is offline   Reply With Quote
Old 01-31-2014, 08:45 PM   #3
You can change the code too as long as you put in the right code first.
2014 Siearra 355RE
Dodge 35000
Old 01-31-2014, 08:45 PM   #4
leencharlotte's Avatar
Keyless door entry
I got one in my new camper as well. If it is a Bauer, Remove the screws from the inside of the lock and there are instructions on the piece that comes off to set your own code
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 02-01-2014, 08:46 PM   #5
Thanks I removed the screws and just like you said the instructions to enter New code.
2014 Siearra 355RE
Dodge 35000
Old 02-01-2014, 09:03 PM   #6
No problem.
Old 02-27-2014, 12:16 PM   #7
No problem.
well we finally got back to beach & instructions are inside the cover but the batteries don't snap into place to I held them in place & DH put back on cover & it didn't work. I guess the batteries are dead that came with it. The design is not good
Old 05-22-2014, 01:23 PM   #8
D-maxx dave's Avatar
Our door wouldn't close properly, had to slam it at times. Factory code would work if door was open. Dealer replaced the lock, all is good now!
David & Kelly
2015 Sandpiper 355RE
2015 Silverado 3500 CCSB SRW 4X4 D-maxx
Nights camped in 2016:03😄
D-maxx dave is offline   Reply With Quote
Old 07-27-2014, 08:22 PM   #9
Just got my new Sierra, mine will lock superiorly , just super easy, but it wont unlock and the key works super super easy so I know the latch isn't binding. If I don't close the door to test it it will lock & unlock no problem close the door nope lock only. And like I said it unlocks with key super easily so its not binding????
mrwoodmin is offline   Reply With Quote
Old 07-28-2014, 10:54 AM   #10
Try changing the batteries? This mechanism is weak. You may not feel the drag with the key. Just a thought.
David & Kelly
Old 07-29-2014, 11:47 PM   #11
I had issues with mine not working at times and also the door being difficult to open. Adjusted the bolt catch to be further towards outside of camper and it made it better. The lock was tight against it before
2011 Ford F350 SRW
Old 08-01-2014, 01:46 PM   #12
I just got a 2015 wolf pack 315 wp a month ago with the key less entry on it but no one at the dealer can tell me how to set it up either. Need heip please
hjacks4 is offline   Reply With Quote
Old 08-01-2014, 05:55 PM   #13
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
If it's a Bauer lock check out their website. There are videos that show how to set them up and manuals you can read and copy. If it's not a Bauer, try to determine who the manufacturer is and look up their website. It's a shame that your dealer did not have the initiative to get you an answer. You might want to remember that next time your in the market to buy another RV.
https://www.bauerproducts.com/
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
Lloydg is offline   Reply With Quote
door
