Old 05-15-2017, 08:37 PM   #1
Leaks under shower door frame
Anyone else having the same issue . 2014 saq365. When showering water leaks under the aluminum sliding door frame that sits on the plastic tub base and onto the floor. Ive caulked it several times which only last a short period of tie. Very frustrating.
THANKS!!!
mrwoodmin is offline   Reply With Quote
Old 05-15-2017, 08:55 PM   #2
chop249's Avatar
Yep. Are you caulking inside the shower, in the frame or outside the frame? I caulked outside the frame and in the frame. It seemed to have cleared up most of the problems. I haven't figured out if the little I'm now seeing occasionally is from a leak or when we step out of the shower to dry.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 21/18 = 11
chop249 is offline   Reply With Quote
Old 06-18-2017, 08:50 PM   #3
Yes I have caulk ed both out side edges and the inside seams. It only last a short time though. Im also using good silicone not the el cheap stuff'
Old 06-18-2017, 08:58 PM   #4
crunchman12001's Avatar
My Coachman leaked where the glass met the aluminum. I found the leak by spraying soapy water on the outside and used compressed air on the inside.
The rubber glass gasket was leaking.
2015 F-250 FX4
door, frame, leak, show, shower
