Old 10-09-2017, 10:19 PM   #1
Mannygok
Stabilizer jacks
Am buying a 41 ft destination trailer. Do I need to have stabilizer jacks installed ? It going to be on a site for 6 months or should I use concrete blocks under the frame at the corners ?
Mannygok is offline   Reply With Quote
Old 10-10-2017, 06:27 AM   #2
Either will work but under the jacks I would put something solid to help keep from sinking. If moving it later using blocks means moving them also, jacks are attached. I have even seen folks use both for a more solid stand and less bounce inside the unit.
dblr is offline   Reply With Quote
