Old 01-01-2019, 09:57 AM   #1
Manual slide question
Anyone know where the nut is to manually retract the slide on a sierra 378fb?
RonandMarion is offline   Reply With Quote
Old 01-01-2019, 10:01 AM   #2
koller1509's Avatar
Look at the top of your pump, what is the problem??
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 01-01-2019, 10:03 AM   #3
Living room slide will not retract.
Old 01-01-2019, 10:09 AM   #4
Coach
Just curious as to whether you have a single switch running all your slides? If so, and the other slides have closed, spinning the pump may not work. You may have a physical obstruction.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 01-01-2019, 10:12 AM   #5
Hooked it up to the truck and slide came in fine.
Old 01-01-2019, 10:13 AM   #6
koller1509's Avatar
Do the other slides move ok?? If so the solenoid for that slide might be stuck.
If none work look in the compartment where the pump is and you will see an in-line fuse, check it.
Larry
Old 01-01-2019, 10:13 AM   #7
koller1509's Avatar
Sounds like low battery.
Larry
Old 01-01-2019, 10:19 AM   #8
Batteries show charged but we think that it must be a battery problem also. Thanks!
manual, slide
