Old 04-22-2018, 09:17 PM   #1
Master bedroom slide leak 2014 Sierra
Thought I’d share. Be sure to look under your slide out when it’s out after a good rain or a wash, do when gets wet with the slide outs out. Check under the plastic edge trim to see if you have any water under the trim. It’s the plastic trim on each side. If u do have water there it’s not pretty. I will advise anyone who wants to do the repair. I’m wondering if this is a common problem. I’m pretty sure found the water source on mine
quick83 is offline   Reply With Quote
Old 04-23-2018, 08:33 AM   #2
Towe443's Avatar
Is this what you are talking about? This is a view from the bottom of my bedroom slide. I put sealant around all of the screw heads on each side of the slide and haven't seen it getting wet since.Click image for larger version
Towe443
2016 Chevrolet 3500HD
2017 Sierra 371REBH
Towe443 is offline   Reply With Quote
Old 04-23-2018, 08:34 AM   #3
Yep.
Old 04-23-2018, 08:40 AM   #4
My water was getting INSIDE the outside frame of slideout and going under plastic and then into Rv. [emoji849]. Click image for larger version
ID:	169304 dripping from where frame pieces meet.
2014, bed, bedroom slide, leak, roo, sierra, slide
