Old 08-17-2017, 09:46 AM   #1
Need advice
Does anyone know what this piece is and what it is used for? It is on a Sierra 5th wheel. Thank you.
Mcnet22 is offline   Reply With Quote
Old 08-17-2017, 09:58 AM   #2
I believe this is a holder/support for your electric/lp lines in the slide. On mine the lines and cords are attached to this so when the slide goes in and out it keeps them neat and keeps them from getting kinked.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-17-2017, 10:02 AM   #3
Correct... it is the 'folding' (actually bending) support for the supply lines to the slide.
Many reports here of them breaking and the replacements breaking.
Some have added steel hinges to the ends where they fasten to the underneath.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 08-17-2017, 10:27 AM   #4
alsdas88's Avatar
I had that happen to my replacement part while my 5'r has been sitting still in an RV part for the past 9 months. Brand new part, still broke after one trip from San Diego to Arizona. I will be installing a quality metal hinge to repair the break.
Alan
2012 Ram 3500 DRW Crew Cab, 6.7 HO Cummins
2014 Columbus M-340RK
'69 Chevy C-10, 396BB
alsdas88 is offline   Reply With Quote
Old 08-17-2017, 10:39 AM   #5
Can anyone send me a picture of where is supposed to be connected So I can get that metal hinge? Thanks
Old 08-17-2017, 10:45 AM   #6
One end will be on a metal tube about a half inch in diameter. The other end is screwed to probably a piece of angle iron with two screws. Crawl under and look. It will be very plain where it is mounted. BTY, simply taking the broken piece off and screwing the remaining back will get you by until you can order a replacement.
donniedu is offline   Reply With Quote
Old 08-17-2017, 10:56 AM   #7
Yeah, I was under it when I took the picture but couldn't see where the broken end was supposed to be mounted.
Old 08-17-2017, 11:09 AM   #8
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
Pictures as Requested
This is from our Tracer 235, but should be pretty darn similar.
Good Luck
ID:	148529   Click image for larger version
ID:	148530   Click image for larger version
ID:	148531   Click image for larger version
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
Old 08-17-2017, 11:18 AM   #9
That is exactly what I was looking for. Thank you very much.
Old 08-17-2017, 11:42 AM   #10
YVW = You're Very Welcome
Jeff and Abby
Old 08-22-2017, 11:43 PM   #11
spaach's Avatar
I know I am late to the party but I was working on a blowout rig and had to look these up. Yours looks like a lippert flexguard double. https://www.amazon.com/dp/B00S2ICI5W..._VDqNzb54YPET8
spaach is offline   Reply With Quote
Old 08-23-2017, 06:11 AM   #12
Cool, thank you very much
