Old 10-25-2013, 10:03 AM   #1
no heat
We have the f325 2006 Sierra 5th wheel. We had heat when we went to bed but stopped early morning. Fuses are fine, themostat works for the air, but no hear. Any recommendations?
reikidawn is offline   Reply With Quote
Old 10-25-2013, 10:06 AM   #2
Did you check the propane?
Sargent's Fox Hole is offline   Reply With Quote
Old 10-25-2013, 10:10 AM   #3
Yes. We still have propane.
Old 10-25-2013, 11:13 AM   #4
Try turning it off at the thermostat and then turn it back on. Might of had a large amount of air in the line.
Old 10-25-2013, 11:43 AM   #5
Great Horned Owl's Avatar
Are you running on shore power or on the battery?
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 10-25-2013, 11:58 AM   #6
Denver, CO
garbonz's Avatar
It's a 2006 so the control board or igniter might be bad.. Easy to replace.
Check propane, 12 volt source and cycle a few times. Does the furnace blower come on?
2017 Fuse 23T
Old 11-20-2013, 07:09 PM   #7
had the same problem with my 2012 365saq found it to be the propane regulator this was after i took it all apart and cleaned the orfice and checked it all out
rangerbob2926 is offline   Reply With Quote
